2 members (DavidR, +8Rich),
277
40
Posts837,991
Posts: 39 |
The cork seal on my pressed steel valve cover started to leak so I had my mechanic install a new rubber replacement gasket. The leak is now even more impressive than it was before. It only leaks along one side of the cover. It's a Ford 1600 engine in a '69 4/4. Research on the internet (which can be dangerous) indicates the the steel valve covers are prone to leak. Another alternative might be a cast aluminum cover. From what I can see there is a love-hate attitude to cast aluminum valve covers. Does anyone have any suggestions as to how to deal with a misbehaving valve cover?
Brent W 1969 4/4 Golden Yellow 2 seater 2002 Harley-Davidson RK
Posts: 881 |
is it the 1600 flow engine, there are a number for companies selling parts in the uk look up burton power http://www.burtonpower.com
Very much in the dog house, could be up for rehoming
Posts: 2,814 |
I had a cast alloy rocker cover on my old X Flow, which was oiltight and quite smart to look at. Gerry
Gerry
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Use a steel rule to make sure it's not deformed by over tightening. They are simple to correct with a brass drift and a small hammer. You can test the 'nip' when refitting with a new gasket by cutting a strip of one inch wide cellulose (something like overhead projector acetate) and trapping it between the cork gasket and the head at the suspect area, it should grip the cellulose/acetate before the screw is fully tightened. A little patience and you can sort it.
Posts: 1,036 |
It sounds to me as if someone, certainly not you of course, has been a tad heavy handed. It's possible that the area around the holes that bolt the cover to the head are deformed and holding the gasket and/or cover away from the mating surfaces. Apologies if this is teaching you to 'suck eggs'.
Posts: 39 |
It is an X flow engine. The steel rule technique looks like a good start. I can pick up an aluminum valve cover from Morgan Spares in New York state if necessary. I'll probably have it from them in a week or less. The nice thing about them is that they ship by US Post, thus saving the punishing brokerage charges that courier services levy.
Posts: 1,947 |
No real need for alloy valve covers, except the steel one is easily bent. Start with a flat one, either new or panel beaten flat. Then use as large a washer on the screws as you can get to fit, and don't overtighten.
Use a gasket compound (blue hylomar is good) to stick the gasket to the head and don't use any on the other side. That way, the gasket lasts for ages.
Posts: 1,947 |
Whoops - I've just remembered, the gasket has 'ears' and you stick it to the cover as the steel original has cut-outs for them. The side with no gasket compound is the head itself.
Not a bad idea to use two washers too. A big flat one on the cover, and a spring one above it. Less temptation to overtighten.
Posts: 39 |
Thank you for all of the suggestions. An examination of the cover showed no signs of deformation. The only thing different with it was a switch from a cork to a rubber gasket. Hylomar did the trick and there is no longer any sign of a leak.
Brent
