6 members (John Winn, +8Rich, JMcL, Craig Jezz, Image, Guten), 310 guests, and 65 robots.
+8Rich 84
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,435
Page 5 of 12 1 2 3 4 5 6 7 11 12
Laurens #227919 12/10/14 01:19 PM
I thought I had read here, that someone was suggesting milling out parts of the S&S logo and putting mesh behind it, so that cold air could be introduced into the centre of the chamber, then allowed to exit around the edge with the spacer installed. If I didn't read it here, then, would that work?
Laurens #227921 12/10/14 01:29 PM
Interesting thread, especially Charles' post above (of which I understood about 50% but enjoyed reading).
Paul; Would there be am issue if water was forced in at speed with your solution?
Laurens #227923 12/10/14 01:32 PM
There could be some shielding behind the hole, and water allowed to drain out through the gap at the bottom. It would, however, be a good idea to spray ACF50 metal protector over everything.
Laurens #227927 12/10/14 01:49 PM
water brings alot of questions for me.
-Could it get into the oil ciculation system?
attatched are some schematics. I don't know anything about this but it is an interesting pictre.
-Rust on the non aluminium parts.?
Laurens #227931 12/10/14 02:32 PM
Well, if S&S are happy to allow a gap all the way around the edge, which, as I understand it is what they are now recommending, they can't be too worried about water getting in. The chamber has no oil or oilways in it, so that won't be a problem, and belts work fine in the wet, probably better, as they won't squeak as much!
Nice diagram btw.
Laurens #227952 12/10/14 04:08 PM
Yes Paul, thats another idea from the Dab of Oppo R & D dept. Currently enjoying the sunshine in Costa del West Yorkshire.
Might give the idea a whirl over the winter though.
Laurens #227970 12/10/14 04:46 PM
I am considering combining Dabs front intake idea for cool air with Dan Lockwoods ally gasket with slots idea for exhaust for the hot air.
Just need to sort out a few details , like a suitable grill behind the front intake.
Laurens #227975 12/10/14 05:06 PM
The use of high ventilation around the cam belt is nothing new in the car industry. On my first Golf Diesel 1975, a little mouse slipped in onto the belt and got killed moving the belt a couple of teeth. Luckily the motor didnīt crash and I could limb out of the forest to a garage. Hard to find the reason for the problem though.
Stig
Laurens #227979 12/10/14 05:17 PM
With regards damage to valves. It can't happen as in a non interference engine. The space that the valves occupy at any point in their travel is not shared with the space that the piston occupies at any point in its travel
Laurens #227980 12/10/14 05:21 PM
Have a look at this. It is an S & S engined motor cycle I saw at classic LeMans this year.
The cooling air intake is on the drive belt side of the engine but it's still a drive belt I suppose.
