2 members (Burgundymog, Cat302), 380 guests, and 45 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,331
Christoph
Page 3 of 11 1 2 3 4 5 10 11
Dave, The kingpin should drop through the bushes under its own weight, without any "feeleable" slop
Any stickiness or tightness will give rise to poor ride and heavy steering.
Simon at Mulfab
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Excellent job and explanation Dave. You make it look so easy.
Martin (Deano)
DaveW Offline OP
OK Simon, thanks. I'll revisit that at the weekend. I'm just a bit wary of over cutting the bushes! thumbs
As you know Martin, it's far from easy, although there are patches of easyness!
Dave I did my first set in a factory equipped with a heavy hydraulic press and liquid nitrogen and it was definitely not easy, which makes your achievement so remarkable.
Martin (Deano)
Well done Dave.
I have always taken the hubs to the garage for rebushing so admire anyone who tackles it themselves.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
Top work and top tips. Great read as ever.
I suspect a touch of Northern Grit there!
Great write up Dave.
I know know what a reamer looks like.
As usual a great write up Dave.
Ian
Great job - I am impressed, especially of your photos. How do you do it with all the grease everywhere...
thumbs
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
DaveW Offline OP
Thin rubber gloves Thomas - whip them off for the photos - but I've gone through half a box so far in three days.
Liquid nitrogen is a bit thin on the ground hereabouts Martin innocent
To update the story on the brake pad springs and pins - the lead provided by Caparo has led nowhere so I've re-contacted Caparo. The 'Agent' wasn't interested and was unlikely to stock the springs and pins anytime soon.
Having done a bit more research, the unavailability of these items is typical across the classic car scene. The design is AP but commonly used across the BL/Rover range in different sizes. All is not lost because I've just taken delivery of a set of classic Land Rover (RR) rears. These are the right shape, but just 4.4mm too wide. At least I can file them down if necessary.
But I'm now on the case so watch this space. There was a problem with the MGRV8 a while ago when these springs were not available. Despite the weight of MG specialists it took a lot of effort to get these remade. There are also stories on Land Rover forums where the spring clips have rotted away and the pads have dislodged. Peter is absolutely right that the springs should be renewed with the pads. But with Morgans, how many get pad changes? That's clearly why dealers don't stock the parts and don't seem interested. You would also hope that the springs and pins would come with new pads, but it seems that this is not the case.
Anyway........
To finish off, a reminder of some spanner sizes:(Not thread sizes!)
Caliper bolts: 3/4"AF
Hub Nut: 1&1/4"AF
Track Rod End: 9/16"AF
Dmper top & bottom: 9/16"AF (Top also requires Allen Key if nut sticks).
Lower reaction bar - all 1/2"AF (Three on chassis & 1 on lower tube).
Bottom of kingpin: 3/4"AF
Lower damper mount to stub axle: 1&3/16"AF
Top (kingpin) lube bolt: 1&3/16"AF
That's it for now!
