1 members (Gambalunga),
254
Topics49,911
Posts838,146
Posts: 14,750 Likes: 158
Posts: 14,750 Likes: 158 |
If I recall someone asked the instrument maker who claimed it was the heat from the light bulbs that is the problem. It raises the temperature of the air inside and moisture then condenses on the cold glass. Heated instrument glass would solve the problem  They said it does not occur with more modern instruments that use LEDs. I can't imagine why they have not changed to LEDs if that is the case. Has anyone tried fitting LEDs instead of the bulbs?
Posts: 2,781 Likes: 5
Posts: 2,781 Likes: 5 |
Well good theory Peter, but mine does it without the lights on. I have on my 'new' dash layout a switch in the panel that allows me to turn the gauge lights on and off. Tried it both ways.
Steve 2008 4/4 1.8 Duratec
Posts: 398 |
A few years back the wife of a classic Mercedes owner wrote an amusing piece in the local club magazine about what it was like being married to a Merc owner.
Among the traits described was driving endlessly round public car parks in search of a suitably secure parking spot, preferably against a wall or pillar, and always parking with the front facing out, so that the lights and Merc badge were less likely to be stolen.
The tip about parking with the instruments in the sun could go in the wives of Morgan owners list of what its being like married to a Morgan Owner.
But, in Oz at least, the sun is not good for the veneer dash!
Oct 13 build 4/4
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
I don't know what causes it. It is all very mist-erious.
Posts: 1,127 |
Has anyone tried fitting LEDs instead of the bulbs? The current Roadster 3.7´s + the Plus 4 GDI´s have LED instrument lighting as a standard. But - guess what happens?! So "ventilation" is the soultion (if there is any...)
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
My Roadster is far worse than the +4 or 4/4 I had. Over winter I will look at solutions.
Posts: 37,486 Likes: 993
Posts: 37,486 Likes: 993 |
I have no solution as I can't say it bothers me too much as it's the Rev counter I'm interested in and that never steams up, just the oil pressure gauge does normally. I can fully understand if it does annoy you though.
My only observation based on ownership of three different models is : - If you store the car overnight with the roof up or the tonneau fully over this phenomena does not occur in the garage where my car calls home, so I find this no hardship as a remedy for a little irksome problem - typical Morgan ownership a little compromise.
Stored bereft of a cover is guaranteed misting in the winter.
Posts: 986 |
The fuel, temp, pressure gauge on my 2013 4/4 mists regardless of the hood being up or down in the garage or a cover being used. Doesn't worry me too much.
Andy
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
Posts: 295 Likes: 5
Posts: 295 Likes: 5 |
Here's the reply I received back in 2011 from the manufacturer - Caerbont Automotive Instruments http://www.caigauge.com/ (no connection). May be helpful Hi Nick
Misting in instruments is one of our bug bears with the older design instruments, several things have been tried over the years including sachets of silicon to absorb moisture , coatings that are applied to the inside of the glass and several other ideas, the base problem is that the gauge is not sealed and if it were it would have to be sealed with air of zero humidity inside, with air of the humidity that occurs this time of year inside when the gauge is activated through the movements and the illumination, heat is created, the air inside then condenses against the cooler walls of the instrument, either the case or the glass, because glass takes longer to heat than the case because of its thermal conductivity the problem usually exhibits itself there. We have cured the problems over the years by using instrument movements that do not generate heat ie using stepper motors and LED illumination, the current 3 in 1 is of an older design, we are working on a design to change this and will take the design to Morgan shortly.
Hope this is of some comfort
Best regards
Gavin Roberts MANAGING DIRECTOR
Nick Connaught Green Roadster S3 V6
Posts: 3,643 |
Interesting, thanks for posting.
