7 members (TeddyAds, Mogdavid, drew, Strathaven, JMcL, RichardV6, Bitsobrits),
317
49
Topics49,846
Posts837,379
Posts: 1,118 |
Not a cheap tyre then ! RogT
RogT Old Git Racer ex 4/4 sand 2013 +4 GDI Royal Ivory 2015 Ford Fiesta ST2
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
The Avons are impressively expensive. Perhaps this could become an alternative choice?: http://www.mytyres.co.uk/cgi-bin//rshop.pl?PoD=110__D-100614__XBTW does anyone drive his regular 4/4 on 185/70/15? Another Q, I'm wondering if I could order a new 4/4 with Vredestein Classics 165/80/15 instead of Contis? (Tomorrow my dealer will reply on this as well).
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
I'll be changing to those Vredesteins when the time is right.
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
BTW does anyone drive his regular 4/4 on 185/70/15? I have Vreds on and I think they are great. But I think that they are slightly wider than 185 and on the odd occasion they have kissed the rear arches (have taken measures to restrict suspension movement). My rear arches are quite narrow. Between 25.5 and 26cm at the top (inner wood to out side). Will buy them again next time.
Roger 2011 Plus 4
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
The 4/4 Anniversaries came with Avon CR6ZZ's - 185/70HR15. About 12mm more radius (ground clearance) than the standard 195/60 R15 tyres fitted to the Plus 4.
Peter regarding your plus 4 you should need a 195/65/15 to achieve a comparable height. I only have found winter tyres of this dimension.
If you have 6.5J rims why not to try 205/65/15?
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
White ivory 75 th anniversary from borghi is mine now. Thank you Peter for yours advises See you soon on the lack of como ..what else.
Congrats a lot! With her you have got a really terrific looking and (I would guess so) fantastic driving car! Enjoy all the happy motoring with her.
White ivory 75 th anniversary from borghi is mine now. Thank you Peter for yours advises See you soon on the lack of como ..what else. Congratulations Raphael and Odile. I know you will enjoy it enormously. It really is a very special car and great to drive. See you soon..
If you have 6.5J rims why not to try 205/65/15? 205s would be wider than the mudguards. Michelin, Toyo, and Bridgestone all make pretty good 195/65 R15 summer tyres in H or V rating. The only thing is they have a slightly higher load rating at 91.
