0 members (), 416 guests, and 63 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
Page 9 of 12 1 2 7 8 9 10 11 12
Laurens #261161 20/03/15 08:05 PM
Just received a return call from my local S&S engine specialist. He contacted S&S about venting the cam belt cover and he told me they just came out themselves with a new vented cover for our engines.
I ordered one then and there and should receive in in a week or so. Will report asap as to their method. He also mentioned they have a spacer kit as well (cheaper than the vented cover) but I opted for the new cover.
ferrisl #261171 20/03/15 08:53 PM
Pics, pics, pics please ;o)
Cheers,
Georges
Laurens #268038 17/04/15 02:29 PM
Well I have fitted my cam belt cover. It is quite ugly but functional and i hope it works. It is made from layers of laser cut stainless sheet steel. Bent into shape.
It is designed to not let in rain with a lip.
I might add more rubber sealing to this end.
Allows cooling through a slit at the top of the recessed plate. I have made it so I can add automotive air filters to the appeture if dust becomes an issue. Hence the central 6mm nut.
The air then passes out through a lower and larger apeture at the bottom which is at lower pressure being behind the number plate. There are internal guards to stop pebbles and stones from getting in at this lower end.
Black to maximise radiation.
much larger internal space for better circulation.
I had to put in a spacer for the number plate holder.
it is just two metric 8mm screws to check the belt now. No need to worry about over torqueing
I would do it differently another time. Good learning exercise. I am happy with my prototype apart from the ugly factor. Just the cover part needs to be changed to give it a better look.
Laurens #268061 17/04/15 04:17 PM
do you get puppets peeking out when you open the window? wink
form follows function. weldone
ferrisl #273450 09/05/15 09:17 AM
Pic below of the spacer kit , Morgan part SP130133, available from your favourite dealer now.
Laurens #273484 09/05/15 02:49 PM
4 capscrews and 4 thick washers. Don't tell me, £49.95 + VAT?
Laurens #273494 09/05/15 04:26 PM
£20. The deep chroming on the screws and washers matches the existing cap screws and looks right. So while I initially winced, its probably fair.
That said you could fit any old rubbish and save a few quid.
Laurens #273495 09/05/15 04:41 PM
You could probably do with the stock bolts and just get washers.
Laurens #273499 09/05/15 05:19 PM
I used 2 off 1mm stainless washers from local stockist on each bolt, cost £1 and stock bolts.
Laurens #273502 09/05/15 05:36 PM
Couple of quid extra will get you stainless bolts to replace the chromed originals.
