7 members (Chris Cosher, Graham, G4FUJ, Morganmike, ScotiaSteve, TBM, SteveT, Simon), 312 guests, and 85 robots.
Sagging Hood
Topics49,859
Posts837,481
Page 1 of 4 1 2 3 4
#231757 02/11/14 11:41 AM
Good morning to all,
I will put my 4/4 in the garage fore the next 3to 4 months.
Which is the best tyre pressure of my 4 Vredestein sprint classic 165 x 15 tyres while storing for that long period.
I hve always 1.2 BAR pressure while on the road as given in the Morgan handbook.
Thanks in advance for your advice.
Best rgds
Herman
I run mine at 25 psi which I make 1.72 bar. I leave it that over winter and move it up and down the garage every now to stop them flat spotting. They've been fine for the last 22 years.
1972 4/4 2 Seater
I normally drive mine occiasionally to stop flat spots on the tyres.
Go Mog has advice for long winter storage
http://www.gomog.com/allmorgan/morganstorage.htm
They talk of 15 psi extra or axle stands
Good Lord, You keep your tyres a long time!
Best Regards
Lang may yer lum reek
Must be like driving on a skid pan? Or is it only tyres of recent years that go hard over time?
Roger
You could always buy a set of these to prevent your tyres deforming. Probably cheaper to drive the car every couple of weeks. Gerry.
https://www.autopyjama.com/tireshoes-uk/?locale=en_US&gclid=CPPSg_iw3MECFabLtAodLzsADg
Gerry
Drive on the Wild Side
Best rgds
Herman
If you can I would advise putting the whole car up on axle stands, this will mean the front suspension will sit lower down and any possible chemical bonding between the king pins and bushes will be out the way on normal road use. Also the tyres will not flat spot, plus you can get under it now and again for some winter cleaning, if you feel up to doing some. cheers
Adrian
Move it on a regular basis, otherwise 50 psi.
Don't forget to adjust in the spring tho' !
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
thx.
thank you
Page 1 of 4 1 2 3 4
