1 members (DavidR),
350
78
Topics49,867
Posts837,614
Posts: 1,245 Likes: 30
Posts: 1,245 Likes: 30 |
Thanks Dave last time I looked I couldn't work out the size. Bob
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Using Diesel oil in a petrol engine Dave ?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Excellent info as ever Dave.
Richard 1976 4/4 4 Seater
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Great post, thank you Dave
Posts: 5,657 Likes: 4
Posts: 5,657 Likes: 4 |
Great post, thank you Dave +1 your TM user name should be changed to Mr Haynes.
Martin (Deano)
Posts: 12,259 Likes: 318
Posts: 12,259 Likes: 318 |
A very thorough post as usual, Dave. I use a Gunson Eezi-Bleed for my brakes, I must confess I've not done the clutch yet as I can't find the slave cylinder! (help required- 1800 Zetec) As for disposing of used oil, here in UK our local recycling centres (read- town dump) will usually have a dedicated tank. Gerry. Me too, I find the Eezi-bleed makes the whole process very quick and simple. Is the Zetec not a cable clutch?
Posts: 1,597 |
Dave another excellent journey into the depths of a Morgan, although I have no intention of going there myself I was fascinated.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
A very thorough post as usual, Dave. I use a Gunson Eezi-Bleed for my brakes, I must confess I've not done the clutch yet as I can't find the slave cylinder! (help required- 1800 Zetec) As for disposing of used oil, here in UK our local recycling centres (read- town dump) will usually have a dedicated tank. Gerry. Me too, I find the Eezi-bleed makes the whole process very quick and simple. Is the Zetec not a cable clutch? My 94 one was
Posts: 306 |
Hi Dave May I ask why you used oil for a Turbo DIESEL in a petrol engine. David
1997 Plus 4, Metalic Blue. 2000 Toyota Yaris. (The Tardis)
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
A good question. I chose that oil on the basis of viscosity and being fully synthetic. It is said to have more robust qualities as required by Turbo Diesel engines, but basically oil is oil. I nearly opted for Mobil 1 which I have in the Roadster, but the viscosity doesn't quite match what the handbook suggests, so Castrol it was, but maybe a bit over the top.
Eezibleeds? - not a fan - too much risk of squirting fluid about for my fastidious tendencies!
The nipple caps came with the car, so if not MMC, are BHM.
