2 members (DaveK, M3WMW),
239
35
Topics49,911
Posts838,148
Posts: 92 |
When I make a tight turn the handbrake light on the dash lights up intermittently during the turn. Has anyone experienced this issue? If so, was it a sensor or a cable adjustment related issue? I'm not sure that I'm worried if it's a sensor issue, but I would be concerned to overtax the system if it's a cable problem.
I've sifted through past threads, but have been unable to find an answer to this. Any help would be greatly appreciated.
Thanks!
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Handbrake with be a simple switch Depends on your model see Daves second picture http://www.talkmorgan.com/ubbthreads.php/topics/173010/Handbrake_lever_lubricationor pre 93 models mounted on rear axle It will depend on your model though
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Are you sure the brake fluid isn't low, that light on most cars doubles as a low fluid warning light.
That's a very good point!
Posts: 92 |
Thanks all for the quick responses. The break fluid is a very, very good point. It was a little low on my last check, but I didn't put two and two together; I will top up and see if it gets me there.
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
I have the same issue on my MTW. In long and fast turns the control light comes up from time to time. Brake fluid level is OK.
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Hi On later models the brake light is dual function:
As others have said it is a low fluid warning light , but I do not think triggers until the master cylinder reservoir is pretty well empty , so don't rely on it!
Secondly it functions as a "handbrake on" switch, so there are contacts between the handbrake and the transmission tunnel . These contacts can become rather dirty due to oil and dirt build up , in which case they will trigger "false" alarms. I had the same issue on my +8 , every time I indulged in heavy breaking the light would illuminate , which I eventually traced to these contacts.
However , they really are placed in a most inaccessible place , so unless you have access to a lift and can work under the car , the only other method of access is to remove the transmission tunnel. This is again not a hard job , just time consuming as you have to first remove the seats (in itself quite a job as the nuts under the car are likely to be seized AND damaged) and then the tunnel. While it is off and you have access, you can do quite a bit of other preventative maintenance (e.g.: pedal bracket, clutch mechanism, inspect gearbox mountings etc)
Andy
Posts: 1,461 |
I had this and checked the fluid level. It looked correct, but after a small top-up, the problem went away. The sensor seems to over-react.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Thanks! Are we talking M3W here, or something else..?
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Mine does it as well. I put it down to the positioning of the switch rather than any problem as such. The harder I corner on right handers the more likely it is to come on...I reckon it's just the car showing its appreciation for some proper cornering.
