Morgan Aero 8
1 members (+8Rich), 281 guests, and 35 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,149
Georgetoad, woolfie
#23371 12/11/08 11:34 AM
Y
Yuri Offline OP
Y
Yesterday had a time to work on my car.What left is to fit the windscreen and small pipe from aircon.Simple.1 during installation one wire from windscreen broke off together with contact inside the glass windscreen must be heated because blower from car heater does not exist(I will do it).So spend 2 hours to solder contact back I was afraid the glass will crack form soldering heat.Tried to bend the pipe to fit it - it cracked,remove soft roof,and hard top-twisted.Now jobs to do:Fit the blower to windscreen,install adjustment for the windows rails,install better weather seal for the windows,inspect and improve seal under windscreen wipers to prevent water ingress in the dashboard,inside the doors water drain hole must be drilled to prevent damage to electrical contacts and motors.I think risk of water ingress and following deterioration of wood and electrical parts is grate.
Yuri #23372 12/11/08 12:47 PM
Keep up the spirit, Yuri! arr
We're all waiting impatiently to see the car finally been driven by a heterosexual, don't let us down!
spudgun #23377 12/11/08 09:43 PM
Y
Yuri Offline OP
Y
Look at this craftsmanship.
Yuri #23378 12/11/08 09:47 PM
Y
Yuri Offline OP
Y
And this side.
Yuri #23379 12/11/08 10:00 PM
Y
Yuri Offline OP
Y
window fame fixed to the top of wooden frame, 3 bolts.adjustment bolts thrue the safety bar.
Yuri #23380 12/11/08 10:04 PM
Y
Yuri Offline OP
Y
Now 3.6mm gap between glass and door,wider weather stripe needed.
