Yesterday had a time to work on my car.What left is to fit the windscreen and small pipe from aircon.Simple.1 during installation one wire from windscreen broke off together with contact inside the glass windscreen must be heated because blower from car heater does not exist(I will do it).So spend 2 hours to solder contact back I was afraid the glass will crack form soldering heat.Tried to bend the pipe to fit it - it cracked,remove soft roof,and hard top-twisted.Now jobs to do:Fit the blower to windscreen,install adjustment for the windows rails,install better weather seal for the windows,inspect and improve seal under windscreen wipers to prevent water ingress in the dashboard,inside the doors water drain hole must be drilled to prevent damage to electrical contacts and motors.I think risk of water ingress and following deterioration of wood and electrical parts is grate.
