8 members (Robbie, Tweed19er, Morganmike, Themorganeer, tommog, Alistair, JohnHarris, Graham, G4FUJ), 225 guests, and 76 robots.
Topics49,846
Posts837,383
paul55 #233975 12/11/14 11:14 PM
Drive on the Wild Side
Having driven both setups albeit on a plus 8 (mulberry) and plus 4 tourer sport (Suplex) I would say the following. If you want to tour and have as comfortable ride as you can in a Morgan then it's Suplex with rear ended set up to match, the rear end has a significant impact on the front, ask Aeroman. I set up my Plus 8 with a Mulbery front and rear end and AVOs and it was great a little stiff but great if you were and aggressive, trac day or fun run hill climb chap. With respect to steering dampers be very careful as to and what you fit if they are not right then they can impeded the steering movement at particular lock positions and could be dangerous. I had my steering adjusted by Nine Elms on the +8 to ensure the track rods were as parallel to each other as possible and this removed any wobble and steering was as light as can be expected on a+8. Hope this helps.
cheers
Adrian
paul55 #233990 13/11/14 06:28 AM
paul55 Offline OP
There is always a great debate on Suplex. My Plus 8 is essentially set up as per Adrian's last post and I do not poodle around on the open road. It has a firm ride but not harsh. I think I will replace the king pins and try shorter rebound springs first before taking the leap. Thank you all who commented.
AJSki2fly #234011 13/11/14 08:26 AM
Nine Elms?
Have Tim and Darren been growing trees again?? laugh2
Nine Elms?
No, it's the new Battersea branch, haven't you heard? :-)
paul55 #234067 13/11/14 03:14 PM
Ah,
Rejuvenating a power station? smile
paul55 #234101 13/11/14 05:42 PM
If you dont have damper blades on your Mulfab setup, and dont need a steering damper, I wouldnt have though you would need one with a Suplex setup.
nputtick #234210 14/11/14 09:06 AM
I have not had the Mulberry springs fitted but I have now had 3 different sets of front springs fitted to the car. The first, ex-factory, had the ride height of the car too low and was replaced under warranty. Not only was the ride height of the car too low but the suspension was very harsh. The mechanic was convinced that the lower spring fitted was too strong and compressing the upper spring too much. When the springs were replaced the ride was acceptable but it seemed the car had excessive body roll in cornering. I then fitted the Suplex system.
I had been following the development of the Suplex Traditional Morgan Front suspension ‘Refinement System’ and as soon as I could lay my hands on a set I had it installed. The benefits have been described elsewhere by several people but it is worthwhile mentioning a couple of them again.
Firstly the upper spring system: It is a double spring system in which the outer main spring is adjustable for the weight and ride height of the car and the inner, ‘Rate Riser’ spring , does exactly what says and as the main spring is compressed it takes up on the ‘Rate Riser’ spring increasing the force required to compress the set. The benefit of this is a supple initial ride that gets stiffer as the spring is compressed.
The lower spring: Traditionally Morgan cars had a lower spring under compression. You can think of a compressed lower spring as contributing a pre-load to the upper spring that disappears as soon as it becomes unloaded. This was what caused the "nodding-dog" syndrome on some older Morgan cars and also caused an initial hard ride that softened as the lower spring became unloaded. This was the reverse of what is desirable.
The Suplex lower spring is set so that it is not under compression at static ride height. This means that it is not contributing to the initial rate of the upper spring, as it would be if it was under load. Also, importantly, it is very stiff. This limits the rise of the inside wheel in cornering and effectively works in combination with the rising rate spring on the outside wheel to reduce body roll in cornering. My car corners very well with little body roll.
For older cars the Suplex kit comes with a set of bearings that replace the old friction blade system. This is not needed on newer cars but can be used to replace old worn bearings and seals if necessary.
The Suplex Traditional Morgan Front suspension ‘Refinement System’ is optimised for road use with a set of Bilstein dampers that are made specifically for the system. I understand that there has been some work done on a competition system that would have much stiffer springs and an adjustable damper, but if that was of interest you would have to talk to Suplex about it. My understanding is that it would provide even less body roll in cornering and a faster initial turn in, but a harsher ride on public roads.
I'm not associated with Suplex in any way, I'm just a happy user.
paul55 #234215 14/11/14 09:47 AM
Like wise I am pleased with my Suplex fit.
I understood the dampers prevent shimmy that may occur under heavy braking, also this may only effect the big cars. I removed the dampers from my little 1600CVH and found no ill effects so they stayed off.
It is literally only a 5 minute job.
Gambalunga #234258 14/11/14 04:38 PM
Perhaps I should clarify that the dampers I mentioned are the suspension dampers, commonly know as shock absorbers, not steering dampers.
Nine Elms?
Just in time for a few rebuilds laugh2
Adrian
