0 members (), 130 guests, and 21 robots.
+8Rich 102
John V6 67
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
International Morgan Day
by Deejay - 17/09/26 02:45 PM
2001 +8 Temperature gauge
by AlanB - 16/09/26 07:39 PM
Longest owner?
First Morgan as it is now
by Strathaven, September 15
Topics49,928
Posts838,441
Fuel.inj
Rober51 #234241 14/11/14 01:06 PM
I would crank the engine with the distributor cap off to verify that the disttributor is actualy turning and not that the timing belt fell off and the cam is no longer turning ,nasty but i have seen it before on fiats .
Rober51 #234250 14/11/14 03:40 PM
Back on fuel, after cranking the engine over, are your spark plugs wet with fuel? Wet will suggest no spark; dry will suggest no fuel getting through.
You've probably tried this already but have you tried removing all plugs, then spinning the engine over on the starter whilst holding one plug connected to an ignition lead to the block? You should see the spark plug spark.
