7 members (GrumpyPa, Morganmike, Sir Percival, JMcL, Chris Cosher, Alistair, TBM),
326
Topics49,842
Posts837,331
Posts: 374 |
Nadvys - was that at your expense? Is it costly?
Posts: 215 |
Vspec - my expense , 1500 eur incl VAT , 4 manhours.. i can give you details of parts
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
Just received my 280mm sender from eurospares, fuel gauge has gone from 12% upto 63%, that the best part of £50 spent just to get the correct fuel reading on a £30k+ car, if i tried telling anyone outside of the Morgan world i'm sure they wouldn't believe me!!!! Just need an empire kit, rear sprocket, and a steering wheel that doesn't bend !!
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 342 |
hugo, can you provide me the part and website where to order it....I also want to get a gauge who is more reliable than the factory one. many thanks in advance
Cheers, Georges
Posts: 1,562 |
Sticky thread please forum admin - 'Must Have Parts' ?
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The website is www.europaspares.com and it is a VDO part, p/n 224011000280G. It's an easy job to replace it. Although the accuracy is better than the original 240mm sender, in that it doesn't show 0% with half a tank or more of fuel, it is not "normal car" accurate. I still reset the trip distance when I fill up and look for fuel at 200 miles or so.
Posts: 374 |
Just received my 280mm sender from eurospares, fuel gauge has gone from 12% upto 63%, that the best part of £50 spent just to get the correct fuel reading on a £30k+ car, if i tried telling anyone outside of the Morgan world i'm sure they wouldn't believe me!!!! Just need an empire kit, rear sprocket, and a steering wheel that doesn't bend !! Have you already got the centa drive, cooling kit, new rectifier position and upgraded bobbins then?
Posts: 491 Likes: 6
Vspec....yes all the thing you have mentioned plus a 2014 chassis, can you believe the gearknob was held on by wrapping tape around the top of gear stick !
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
"can you believe the gearknob was held on by wrapping tape around the top of gear stick"Yes, I can, it's a Morgan and it depends on who made it. I'm not saying that is the way it should be of course, and if they were proper car makers it wouldn't be like that, but .........
Posts: 342 |
Thank you planenut
Cheers, Georges
