2 members (JoeSpeetjens, Bitsobrits), 253 guests, and 103 robots.
Topics49,847
Posts837,389
#23407 14/11/08 09:16 PM
Ivo Offline OP
TM Photographer of 2011
Hi all,
I have a question, concerning the anti-tramp bar, installed on my Roadster II.
In February, its rear fixing bolt (the one on the axle) broke. After having fixed it, my dealer said, the new bolt would last forever, because before it was "under tension" and now it isn't anymore.
Well, "forever" turned out to be a pretty short time, because today, 9 month later, the bolt broke again.
I want to point out that both times it happened during normal (not "enthusiastic") driving.
Anyone else experienced such a situation? Any ideas what could be done, so it will not happen again?
Thanks for your replies. smile
Ivo
sunny
1998 +8 (permanently out of service frown )
Ivo #23412 15/11/08 09:47 AM
Y
Y
Ivo ! can you send a photo please.
Yuri #23414 15/11/08 12:14 PM
Ivo Offline OP
Hi Yuri,
Unfortunately I don't have a picture of my bar, but here is a description with pictures.
The Roadster II has just one, on the right side.
Salut,
Ivo
sunny
Ivo #23415 15/11/08 04:29 PM
Y
Y
As I can see your tramp bar is adjustable.If it too long,or too shot, the bolt will be "under tension".My best guess will be wrong length.Compare both of them and readjust the one which shire the bolt.
Yuri #23421 15/11/08 05:56 PM
Not too sure I like the blocks whether needed or not, often I find that when this sort of kit fitted one side is done up tight first then the other, this sort of kit requires everything to be absolutely square then done up tight, also there needs to be some precision such that the whole assembly is square and right
Yuri #23422 15/11/08 06:35 PM
Ivo Offline OP
Thanks Yuri, I let the dealer sort it out. The car is still under warranty.
I don't understand, why Morgan only fits one bar....
sunny
Ivo #23423 15/11/08 06:44 PM
Hum hum... The broken bolts were on the same side each time?
(this kind of question give the impression I have something interesting to say "behind my mind" about this problem... :-) )
H3
H3
h trois #23424 15/11/08 08:30 PM
Ivo Offline OP
The car comes with just one single anti-tramp bar.
sunny
Ivo #23439 16/11/08 02:03 PM
hhhmmm.... not sure that's right.. .thought you should have 2 and also a Panhard Rod to keep the Axel laterally located..(this BTW could possibly cause enough angular load to snap the head off the bolt?)
Ivo Offline OP
They all come with just one. ...a design problem?
sunny
