1 members (ChrisConvertible), 206 guests, and 89 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
ini Offline OP
Oh no! Not another fastidious Morgan owner hide
No idea how you come to this conclusion doh
Back to Topic:
Second reflashed speedo arrived and it looks like the solution.
After changing the speedo I tested on the Autobahn from 90 km/h to 180 km/h (first time so fast) and everything worked perfect. joy Also the AVR function seems to work correct now joy .
For those with the new VDO speedo you should check if there is a green dot on your speedo then it is reflashed and the problem should not appear.
Torsten
Torsten
plus 4 MY 2014
I have a +4 delivered end of July. Having read your post a friend of mine pointed out that my odometer does not work at higher speeds and the needle is very erratic above 55 mph. Reported erratic reading to dealer who said he would replace under warranty but nothing happened yet.
ini Offline OP
AS explained above your dealer should reflash at the factory and everything is OK. It is a well known problem.
Torsten
Torsten
plus 4 MY 2014
All fixed now I presume?
