1 members (GLLOQ),
209
32
Topics49,897
Posts838,018
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
Frunni, Great stuff - one for the archive!!
Many Thanks!
Posts: 27,838 Likes: 764
Posts: 27,838 Likes: 764 |
Looks like garden hose quality fittings, no wonder they fail so soon.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
When I had my BMW318i I had the plastic header tank split from top to bottom, later the plastic outlet from the water pump split. .All cheap naff stuff. Not what you expect when you buy a quality car.
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
What worries me is plastic master cylinders...
Graham I have on the shelf a 1972 mexico one, to the eye it looks OK. Could be different material to modern ones.
The clutch master cylinder piston on my old Dodge W200 4x4 was plastic with a rubber seal, but the actual cylinder was metal... Can't remember the fluid reservoir now.
Posts: 4,896 |
I have not looked at the radiator in detail on my Roadster but presume it is the same. I think if mine goes I will take the radiator out and pop down to my local radiator repairer he took my Plus8 rad apart and put a new core in, better than original for 40% the cost of a Mulfab one. So I am sure he should be able to replace the plastic fitting by braising on a a suitable brass one on instead and hopefully would never fail again. I suspect if not hard to do no more than £50-100.
Why not see what your local radiator repairer could do. :santawave:
Adrian
Posts: 14,009 |
Just checked my radiator. It's fine but the electric fan shroud mounts have sheared at the top on both sides! The whole thing is just flopping about....
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Just checked my radiator. It's fine but the electric fan shroud mounts have sheared at the top on both sides! The whole thing is just flopping about.... Must be all that unusable power  you'd be better off with a narrow bodied + 4
Posts: 486 |
Just checked my radiator. It's fine but the electric fan shroud mounts have sheared at the top on both sides! The whole thing is just flopping about.... Must be all that unusable power  you'd be better off with a narrow bodied + 4 Unusable power :santarudy:
Cain
Wolf Cafe Racer 4/4 Sport
