6 members (jbk, Rog G, Julian BB, TBM, +8Rich, JMcL), 200 guests, and 48 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Page 3 of 6 1 2 3 4 5 6
frunni #239698 12/12/14 09:57 AM
Frunni,
Great stuff - one for the archive!!
Many Thanks!
Robbie
2021 Plus Four -- Helga
211-WX-1433
frunni #239704 12/12/14 10:55 AM
Looks like garden hose quality fittings, no wonder they fail so soon.
frunni #239713 12/12/14 11:50 AM
Ray Offline
When I had my BMW318i I had the plastic header tank split from top to bottom, later the plastic outlet from the water pump split. .All cheap naff stuff. Not what you expect when you buy a quality car. ooo gloomy
frunni #239725 12/12/14 12:40 PM
What worries me is plastic master cylinders... scared
frunni #239734 12/12/14 01:07 PM
Ray Offline
Graham I have on the shelf a 1972 mexico one, to the eye it looks OK. Could be different material to modern ones.
frunni #239754 12/12/14 02:09 PM
The clutch master cylinder piston on my old Dodge W200 4x4 was plastic with a rubber seal, but the actual cylinder was metal... Can't remember the fluid reservoir now.
frunni #240059 14/12/14 02:09 PM
Drive on the Wild Side
I have not looked at the radiator in detail on my Roadster but presume it is the same. I think if mine goes I will take the radiator out and pop down to my local radiator repairer he took my Plus8 rad apart and put a new core in, better than original for 40% the cost of a Mulfab one. So I am sure he should be able to replace the plastic fitting by braising on a a suitable brass one on instead and hopefully would never fail again. I suspect if not hard to do no more than £50-100.
Why not see what your local radiator repairer could do. :santawave:
Adrian
frunni #240174 14/12/14 10:31 PM
Just checked my radiator. It's fine but the electric fan shroud mounts have sheared at the top on both sides! The whole thing is just flopping about.... mad2
Jays #240180 14/12/14 11:10 PM
Black Rat
Black Rat
Must be all that unusable power drive you'd be better off with a narrow bodied + 4 rofl
Keith
2013 narrow bodied + 4 Ruby.
Unusable power :santarudy:
Cain
Wolf Cafe Racer
4/4 Sport
