1 members (TalkMorgan), 331 guests, and 38 robots.
+8Rich 95
John V6 52
Posts838,014
rockabilly john
Page 4 of 6 1 2 3 4 5 6
frunni #240212 15/12/14 08:23 AM
Very usable power if used with care.
My Rad is metal & so far so good with the fan. I rushed out to check after Jay's post.
frunni #240313 15/12/14 05:26 PM
The all metal rads were replaced sometime around 2006. I have metal tanks on my Roadster.
The biggest problem with alloy rads is that they are difficult to repair, (I'm told), so if you get a leak, that's not good news. I would also try to flexibly mount to the chassis, to avoid stressing the mounting brackets.
frunni #240884 18/12/14 02:18 PM
Yesterday I noticed a small pool of coolant on the garage floor, on closer inspection it appears I have a leak from the top of the rad on a welded seam. Has anyone used Liquid Aluminium Radiator sealer? Is it worth trying this product before removing the Rad which is only two years old.
Dave
98 +8 Corsa Red
74 MGB Red
MGDave #240895 18/12/14 03:08 PM
I'd bite the bullet, remove the radiator, and get it properly repaired.
1972 4/4 2 Seater
frunni #240921 18/12/14 04:18 PM
Black Rat
Black Rat
+ 1
Keith
2013 narrow bodied + 4 Ruby.
frunni #240938 18/12/14 05:10 PM
Agreed not things to bodge are radiators
frunni #240956 18/12/14 06:42 PM
Even that doesn't always work. My Gilbern had a tiny leak where the top tank was soldered to the core. I went to the trouble of having it professionally repaired, but within weeks it was leaking again, exactly the same.
frunni #240962 18/12/14 06:57 PM
Repaired rads have a habit of letting you down when you least want it eg. queuing traffic in the summer. I would go for new one, relatively speaking, they aren't that expensive.
Martin (Deano)
frunni #241119 19/12/14 05:57 PM
Looks like the best course of action is to replace with a new radiator, what's the correct way to remove the rad, do I have to remove the cowl?
Dave
98 +8 Corsa Red
74 MGB Red
frunni #241139 19/12/14 06:51 PM
This is one job I haven't done (yet) but I'm told that it can be slid out from below. Obviously different models may vary.
