2 members (TBM, Graham, G4FUJ), 325 guests, and 91 robots.
Topics49,847
Posts837,389
Page 3 of 4 1 2 3 4
drk Offline
@Kaou: Thank you for the reply smile
i hope you'll find the solution
Morgan 4/4, Caterham Seven, Ginetta G27, TVR Chimaera
drk Offline
take a look here :
http://www.sscycle.com/uploads/catalog/53/6%20Xwedge_WEB.pdf
section 6-31
you can find any sensor on x-wedge throttle body ( map, temp, position )
maybe can help smile
Kaou Offline OP
Thank you for the link, I never looked for it before.
Hopefully Morgan France will revert to me.
Originally Posted By Kaou
drk: is this answering to you ?
The engine check light is turning on only when :
1 - I release the throttle @ 3000rpm
2 - I push down the throttle to the maximum
The rest of the time, the light is off and the engine work fine.
Hi kaou
My ecu issue started off similar to this, got gradually got worse.
If you use Pro Tune in gauge view you can run the motor and reproduce the actions that usually cause light to come on.
You then look for any of the readouts to flash red. This means they in "fault" even if they don't register.
For me it was the over-voltage readout which went up to 18 volts when blib accelerator above 2500 revs.
I used a screen recording program and made videos of the live gauges whilst driving. This way you can play back and see what's happening.
I don't have the files on the iPad, but when I can I will post a couple of stills and short video if you are interested.
Eventually the choking at low rpm got very severe with masses of black soot ex exhausts. Replacement ecu was the fix
Kaou Offline OP
Thanks a lot for the feedback, I am interested by the video indeed.
I don't have access to my car now, as I left my car in France and I am in Greece...Moreover, it is snowing here since yesterday and I wouldn't try to drive under the snow in Athens !
(I am already riding sideways with a Sportster on dry road...)
By the way, nice to see a Kiwi with a M3W as I may end up in your country sometime !
Be careful! They will drive the MTW upside down! laugh2
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Hi Kaou
Here are a couple of short clips.
The one of the instruments shows the flash of red for an overvoltage of 18 amps, this was spurious as readings by ammeter at those times were fine and no fault codes were thrown.
This was caused by the ECU failing.
The other shows the CEL coming on as soon as the accelerator was released after an acceleration.
hope they are of some interest
nigel
Kaou Offline OP
@ The Austrian : I will be careful thumbs
@ P964 : Thank you for the support but I can't see the videos, or I am too old for forums already ?
Damn and crosswords, was in hurry to get to bed and left the videos off!!!!
Will put up soon as I get back to desktop. iPad won't do it
At last, here are the videos !!!
Page 3 of 4 1 2 3 4
