Topics49,871
Posts837,684
Posts: 1,562 |
The peddles CAN be moved still beyond the factory locations. You use the last front holes in the frame and drill two more holes to the front. But watch out for the clutch pedal striking the hydraulic pipes. This can happen even at the extreme factory setting as has been discussed before (but I can't find the thread) And can be corrected easily by swiveling the pipe unions up and out the way !
Posts: 3 |
Thank you all very much for the comments. It is very encouraging and it seems as if there could be a number of solutions which could work for me.
