0 members (),
298
38
Topics48,341
Posts812,981
Posts: 3,665 Likes: 43
Posts: 3,665 Likes: 43 |
I've always believed my ser 1 roadster is a getrag box. A total delight. Nick
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
+1. That is how I understood it.
Gearbox:
This is a Jaguar 5 speed manual. The remote system is unique to Morgan Motor Company
Posts: 2 |
What year did the Roadster go from S1 to S2? Are there any other telling differences between the two?
It seems like an early 232bhp Roadster is the way to go...
Posts: 4,896 |
I've now driven 2 S2s, including mine and an S3
The Getrag (thanks John, I stand corrected) unit on the 3.7 S3 is a delight.
I was told the box used on the S2 is also used on the Transit. On my car if the change is rushed it baulks, but the lever is easy to move. Quite similar to a manual transmission I had on an old Mercedes. On the other one I drove the lever needs a much firmer push, but it changes more easily.
I wonder if mine could use an oil change, it has run 25,000 miles.. I concur. Also having driven all 3 Roadsters when recently looking, I would say the easiest and most compliant is the S3. the gearbox is great, steering with the electric power assist is great, mine is setup with adjustable AVOs all round and brake reaction bars, the only think I might add is a Panhard rod, apart from that it is one of the best traditional type Morgans I have driven. Finally it is very quick!
Adrian
Posts: 697 |
The gearbox on my 3.7l Roadster is silky smooth, except when cold, when changing too quickly from 4th to 5th produces a graunch. I soon learned to change slowly till the temperature had reached normal, and thereafter the change is quick and silent through all gears. No hanging throttle experienced.
Rob
Bavaria 46, 20% of Hunter Impala. 100% of another Hunter Impala, black 4/4 Competition
Posts: 312 Likes: 1
Posts: 312 Likes: 1 |
Is ground clearance a problem on the Roadster? Bob.
Posts: 1,948 |
.. Or a total car change. Go on, you know you want to
Stuart "There's no skill substitute like cubic inches."
Posts: 21,866 Likes: 167
Posts: 21,866 Likes: 167 |
The S1 Gearbox is Getrag. Now it might be that this was fitted to the S Type Jag, I don't know. The change is fast and smooth, but reverse is a bit notchy. I believe in changing gearbox oils at reasonable intervals, but the Getrag in the S1 was designed around a particular Esso ATF which took a bit of finding. Details are in one of my service "How To's". Remember that the S1 also has the six leaf rear springs, and one dealer (who shall remain nameless) has described the S1 as "agricultural handling". Very early Roadsters are two road tax bands below "normal". The S1 is 223 not 232bhp. The difference between S1 and S2 is easily spotted - the dash on the S1 has the speedo and revcounter in front of the driver with four small gauges across the centre. The S2 got the silly dash with the revcounter in front of the driver and the other (2) gauges in the centre.
Posts: 898 |
Peter General opinion over at http://www.bobistheoilguy.com where they post used oil analysis of engines, transmissions and diff fluids. Change gearbox and diff fluid at 30k miles to get the ware metals from running the unit in, still there at the 60k miles flush and get a true result at 90k miles after the wear iron is out the unit. So good time to change the fluid. Could not find any Ford gearbox UOA's of that gearbox. eddie
Posts: 7,342 Likes: 91
Posts: 7,342 Likes: 91 |
In my understanding, S1 is the first Roadster, fitted with the 3.0 engine, 223 HP borrowed from the S type/Mondeo ST220, matched with the smooth Getrag 5 speed box. This is the the most rev willing engine in comparison with S2 and S3. S1 Engine has barrel tappets to get higher revs and the adjustment is a manual job. Built until 2006 or so.
S2 is from the US, matched with the Ford Transit gear box, 204HP and hydraulic tappets with automatic adjustment. Very relaxed drive, more cruiser than S1. S1 is a bit more lively but S2 also opens up nicely after long running in period. Built until early 2010.
S3 started with the Roadster Sport mid of 2010. Wider front axle than before. Some months later bespoke models became available with same wider front. Same engine as S2 but somehow tuned to 230 HP. Exhaust manifold got a slightly bigger diameter. Same Ford Transit gearbox. After more than 20K km the engine opens up and drives nicely. No rev hanging issues at all with S3 series which is a joy.
I must say, you can get used to the Ford Transit gearbox (S2/S3) easily, but in my view the ratios are not perfectly matching the power/weight ratio of the Roadster. First and Second gear are really too short.
So a 3.7 could be called an S4. A big advantage of S1 to S3 is the comfortable legroom due to the narrower drive train tunnel in comparison with the Mustang 3,7 Roadster.
I'm wondering if some weight has been added with the appearance of the 3.7 Roadster? (more engine weight, servo steering etc?) I never drove a 3,7 but all 3.0 series.
