10 members (Soleng, DCH, DJC, Ncik P, eds, Ritchie B, DaveW, Luddite, Mike D, TalkMorgan),
300
35
Topics49,837
Posts837,286
Posts: 1,338 |
When i got my m3w in november 2013...i found 3 things wrong with it... -aligment -on braking the car was pulling to one side a 10min fix...bleeding the front calipers.. -hard to put into gear..just behind the clutch pedal,there is a rod & a nut,loosen the nut,turn the pedal inwards with your hard,if its abit hard,have someone push down on the clutch abit,turn it inwards a few times,then tighten the nut.thats how we did it over here.felt so much better
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
the clutch may become brittle if the patina often start at high engine speeds, the clutch disc only measure 181 mm in outside diameter, the clutch linings are thin and are bonded to the metal washers for reinforced clutch linings and prevent its instant destruction if heated, for myself the clutch has been removed twice for other problems arise on occasion and cleaned with her tray mechanism and diaphragm spring lubricated with special high pressure grease clutch softens pedal at least 1/3 of strength, I expected to replace the soon to 30,000km by security because it is original and does not damage the flywheel and the clutch mechanism
Posts: 7 |
how much to replace your clutch
Clutch £ 368 was sold by morgan Malvern for labor two hours (200 pounds) included in the price of the updated centa, I thought that my clutch is worn + 30.000km to 20.000km he seemed worn 2/3, so it was the same in wear, I do not regret because I often rolls in town and I asked to recover the old parts.
Posts: 8 |
Do I understand that the Morgan factory replaced the clutch in your recent M3W for 368 pounds with 200 pounds in labor while they were doing the Centa upgrade? What were the additional costs for the Centa parts and labor, if they charged for these separately? I am having both done in my 2012 M3W and need to know what is reasonable. Thanks so much for this valuable information! Keep smiling
