5 members (Gordon D, B3MOG, cerealsurfer, Doug J, BigLes), 142 guests, and 63 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
The pleasures of a hand-built car!
The oil pan is quite strong and will easily support the engine when it's on the ground.
First, try raising the drivers side (left side) of the car using the jack placed on the left of the oil pan. If you're concerned about damaging the oil pan, just go easy and watch the pan from underneath. Use a block of wood to cushion. You should not need to raise it by much and the engine should rotate a little and should give you enough room to wriggle the bolt out.
There's a bit of 'flex' to the engine mounts and in truth, it's the weight of the engine that keeps everything in place. Whilst you're 'playing', inspect the mountings for signs of perishing as, after 44 years, they might be starting to degrade.
gcarguy Offline OP
Eureka.
Took out motor mount bracket bolts (2) on each side.
Raised engine 2" using 2x6 and floor jack.
Much more intimidating than difficult.
We shall see how easy it all goes back together.
Thanks for help
71 Plus8 Yellow/Blk
57 Morris Minor Trvlr 1098cc
93 MB 500E
66 MB 230SL
48 Chev Fleetmaster Conv LS1
Yes intimidating rather than difficult!
Don't forget the thread adhesive or replace the rusty steel bolts with stainless. At least use something like Copperslip.
Thread lubricant not thread adhesive!
