1 members (Montegue),
259
51
Posts837,277
Posts: 9 |
Hi all,I have recently purchased a 2011 +4 duratec engined 2 seater an ex Morgan car with Jenvey throttle bodies,this is my 5th Morgan and the most modern.I,m over the moon with the car apart from a problem with the Ford MT75 gearbox.3rd,4th and 5th gears are sweet as a nut and give a positive change up and down the box,1st,2nd are really difficult to engage and can take quite a bit of force to get into gear(it feels like pushing the lever past a nylon obstacle) I have tried various grades of oil and currently I am using ATF,none have made any difference.I have also bled the clutch. The car is my daily driver and this problem makes the commute a real chore. Any thoughts?Anyone got a the same spec car?
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
My Plus4 has the MX5 gearbox so I can't really comment on your problem from that perspective. But is this something wrong with the selector mechanism I wonder? What does the dealer say about it?
Is selection any easier with the engine off?
Posts: 9 |
Hi Dave,thanks for the quick reply. There is no problem with the engine off,all gears engage with the same smoothness. Do you have a theory?
Posts: 29 |
Similar problem with mine but difficult to change down from 5th to 4th. However it is easing now I have almost 10,000 miles on clock
Howard 2010 Plus 4 Duratec
Posts: 2,583 |
On my 20104/4 sport the MT75 is sweet and positive, however I did read at time of purchase that a couple of people had problems and the shift needed adjusting - gate or something was sticking. Local dealer should be aware.
Posts: 472 |
Sorry to hear about your 'trouble'. Unfortunately I have the same problem and have also tried quite a few 'recommended' oils without any significant improvements. Oddly enough I have noticed that when it's a bit colder it gets a bit easier to change from 1st to 2nd. I've read about that elsewhere on the net and it is suggested that it's because the oil gets thicker and stickier and 'grabs' the sync rings better. A thicker oil could help if that's true - which I also read somewhere...
I will try a few things later this year (when it gets warmer): 1. Check the gear-shift lever housing bushes. They are made of Polyurethane and if they are worn they could perhaps affect the alignment of the whole assembly in a bad way. 2. Check for wear or dirt in the gear stick 'main bushing'. 3. Check for rust/dirt on the main shaft sticking out from the gear box - then grease it. 4. Fit a 'Sports Shift' kit as recommended to improve gear changing on the MT75.
Of course I will publish all findings and results here on TM.
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Posts: 217 |
My 2011 roadster was always a problem engaging 1st gear but during a visit to brooklands test hill i decided to attempt it by pulling away fast in second gear to avoid a mid hill gear change, I got quite alot of clutch burn smell but 1st gear now engages easier !. Have fun trying. Alan.
According to the internet, the MT75 has an unusual synchro hub arrangement on 1st/2nd gears. Vehicles manufactured from build date 17. 6.1996 are fitted with a 1st/2nd gear double synchroniser unitLook at page 00-01-13 here........... http://www.fordscorpio.co.uk/manual/manualtrans/MT75Overhaul.pdfIf it engages OK with the engine off, then the problem is either with the synchro hub or tickover speed is too fast (this wouldn't be as big a factor for 2nd gear. See if there's any difference in engaging 1st gear with a cold engine (fast tickover) and a hot engine (normal tickover). If it's harder with fast tickover then it's either the synchro hub, or clutch drag. Given that the remaining gears seem OK, the former seems more likely.
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
My 2011 Roadster 1-2 shift was stiff when new, eased after 10,000 miles and some hard use
Posts: 472 |
Interesting Dave, easier to engage 2nd with engine off... 1st was never a big problem.
