+8Rich 95
Luddite 54
Topics49,904
Posts838,083
#253184 15/02/15 07:00 PM
Yesterday I took the time to find out with what axle and diff my Roadster 3.7 is eqipped with. So far no surpises, It's the Borg-Warner BTR Spicer Dana... axle. The type is MRA0031, the ratio is 3,73:1. I heard, this is the only choice for the 3.7, true?
But I thought, all Roadsters do now have the LSD??
The Label on my axle says STD, not LSD as it should.
Can I trust the label, no LSD?
Your comments are welcome...
Regards
Ex-Roadster 3.7, now P6
Jack the rear and turn one wheel (gearbox in neutral). If the other wheel turns the same way its LSD. If it turns the opposite way or doesn't turn at all it isn't.
Originally Posted By DaveW
Jack the rear and turn one wheel (gearbox in neutral). If the other wheel turns into Jimi Handrix its LSD.
Best Regards
Lang may yer lum reek
rofl
Great advice. I will try it.
Don McGuire
donsmcguire in Pebble Beach, CA
Don McGuire
If you have time, and know, please tell me where to look for a list of wheels[/color] that will go on to the original spindles that have been installed on a stock 2015 Roadster with 3.7 engine.
Don McGuire
Hello,
have a look at: MWS wire wheels
and: Dayton
Morgan paints in custom colours as well.
regards,
P.S. Don't LSD and drive
Williams Morgan in the uk can supply wheels
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
Erm thinking - the current Roadster 3,7 should have a 3,07:1 (according to current Morgan handbook) ratio WITH LSD (or other mind-widening ingredients in addition to make the sheer power groundable) !
IF yours has a 3,73:1 fitted, not only is your first gear useless (as on std. 3,7s), but so are 2nd (& 3rd, ...).... scared
drive 2015 Roadster 3.7
