1 members (Saxonian),
333
Topics49,904
Posts838,088
Posts: 216 |
Yesterday I took the time to find out with what axle and diff my Roadster 3.7 is eqipped with. So far no surpises, It's the Borg-Warner BTR Spicer Dana... axle. The type is MRA0031, the ratio is 3,73:1. I heard, this is the only choice for the 3.7, true? But I thought, all Roadsters do now have the LSD?? The Label on my axle says STD, not LSD as it should.
Can I trust the label, no LSD?
Your comments are welcome...
Regards
Ex-Roadster 3.7, now P6
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
Jack the rear and turn one wheel (gearbox in neutral). If the other wheel turns the same way its LSD. If it turns the opposite way or doesn't turn at all it isn't.
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Jack the rear and turn one wheel (gearbox in neutral). If the other wheel turns into Jimi Handrix its LSD.
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Posts: 4 |
Great advice. I will try it.
Don McGuire
Posts: 4 |
donsmcguire in Pebble Beach, CA
Don McGuire
Posts: 4 |
If you have time, and know, please tell me where to look for a list of wheels[/color] that will go on to the original spindles that have been installed on a stock 2015 Roadster with 3.7 engine.
Don McGuire
Posts: 216 |
Hello, have a look at: MWS wire wheels and: Dayton Morgan paints in custom colours as well. regards, P.S. Don't LSD and drive
Posts: 2,361 |
If you have time, and know, please tell me where to look for a list of wheels[/color] that will go on to the original spindles that have been installed on a stock 2015 Roadster with 3.7 engine. Williams Morgan in the uk can supply wheels
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 1,127 |
Erm  - the current Roadster 3,7 should have a 3,07:1 (according to current Morgan handbook) ratio WITH LSD (or other mind-widening ingredients in addition to make the sheer power groundable) ! IF yours has a 3,73:1 fitted, not only is your first gear useless (as on std. 3,7s), but so are 2nd (& 3rd, ...)....
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
