3 members (SteveT, Strathaven, cerealsurfer), 217 guests, and 105 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
Page 4 of 13 1 2 3 4 5 6 12 13
The Austrian #254503 21/02/15 08:57 AM
Originally Posted By The Austrian
Waiting for the first MTW live reports of TMers who got the upgrade.
Will have to fit it by myself if Williams does ship the unit to the continent. Driving to the UK is quite a distance for me...
Same for me...fitting should not be the problem, but what about reprogramming the ECU?
Cheers,
Georges
Smaug #254520 21/02/15 10:30 AM
Testing has shown that the mixture is rich in factory form. The closed loop system has feedback to adjust injection and maybe firing times to account for the improved airflow.
The s&s ecu only has limited 3rd party remap options for Morgans at this stage. The vehicle is somehow locked from having non 3wheeler ECUs attached. This is in my opinion umfair commercial practice and limiting behaviour by either s&s or morgan in order to block other firms from improving performance. I wouldnt mind if MMC had released the upgrades by now but it is all looking unlikely. With enough investigation and expertise this will be overcome but is going to be an expensive and high risk process.
Any actor trying to remap the morgan spec ecu runs the risk of irreversibly immobilising the vehicle by corrupting the ecu. Any workaround has to take this into account. However this would be a lucrative venture for any firm as it would be inimitable work. It is a case of whether enough people are interested to make it a commercially viable investigation. Most 3w owners only drive a couple of miles a year...
Smaug #254521 21/02/15 10:31 AM
Williams informed me by mail: "pipe fitting takes less than an hour per side" but did not mention any need for changing the ECU settings
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
charlestkirby #254552 21/02/15 12:39 PM
Thanks for the info....having my ears wide open to see how you two will perform with the stage1 upgrade listening ....and also jump on that train
Cheers,
Georges
geof569 #254658 21/02/15 08:07 PM
R1nga, many thanks for the background to the team behind Gar 56, they certainly sound as if they know their stuff, and it is good that they have chosen the Three Wheeler to concentrate on. As we all know there is so much potential in the car, if only there was someone who had the knowledge to take it forward, and it sounds as if they are the ones.
As a matter of interest, Wikipedia came up with the original reason for the name Garage 56 which was coined at LeMans for experimental cars which could find no class to race in, but who needed 24 hours of racing to develop new technology.
Garage 56
The ACO continued the Garage 56 concept, started in 2012. Garage 56 allows a 56th entry to the race, using the rigors of the 24 Hours of Le Mans to test new technology.
PaulJ #254785 22/02/15 11:23 AM
Originally Posted By PaulJ
...the name Garage 56 which was coined at LeMans for experimental cars which could find no class to race in, but who needed 24 hours of racing to develop new technology.
ha,
yes that is where i will be.
geof569 #255000 23/02/15 09:09 AM
Keen to hear how you get on. I was quoted £250 to fit the kit including vat so £1500 total. Fitting doesn't seem tricky of course but given exhaust failures I would rather be sure it's done properly!
geof569 #255005 23/02/15 09:26 AM
Dreiradschubser
Dreiradschubser
I have seen here a diagram with power output and torque over rotations, but I can't find it again. Who knows a link?
And is there a discussion of this Garage 56 stage 1 kit, sold by Williams and the stage 1 kit of Morgan themselves?
Thanks a lot
Achim who just read that the Garage 56 / Williams kit is sold out actually
Waldemar #255052 23/02/15 12:18 PM
Here's the link:
http://us9.campaign-archive1.com/?u=9a0b4b9ade17cdf7cdfc1b8e3&id=31820988a9&e=57ba2797d6
Interesting the stock motor is producing 100bhp at the flywheel - which would be consistent with 85 at the back wheel.
Red Leader drive
Waldemar #255058 23/02/15 12:26 PM
Try phoning, Williams might not be as sold out as the website says...
smile
