0 members (), 309 guests, and 87 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
Page 6 of 13 1 2 4 5 6 7 8 12 13
R1NGA #257555 06/03/15 08:10 AM
If you could afford the fuel you could go touring in it, its got a cabin trunk strapped on the back.
Tim
The Austrian #257608 06/03/15 11:21 AM
Originally Posted By The Austrian
After ordering the kit I got information from Williams that they went on the net too early and the stuff is not available yet but "in the near future".
Have terminated my order.
I am sure this is because the first batch of kits are still being made - I'm sure they will be shipping soon as they wouldn't have launched without stock being very close.
R1NGA #257611 06/03/15 11:37 AM
Morgan would never do that ! oops
geof569 #257615 06/03/15 11:49 AM
There was also an issue with finding a carrier that would accept the rather large box required for the kit. Don't know if this has been resolved.
geof569 #259186 12/03/15 05:01 PM
I had a short ride in the Garage 56 Stage 1 car at Silverstone the other day with Terence Goad and thought I would pass on my thoughts on the kit. It was a new experience for me being a passenger, I was not offered a drive for insurance reasons, understandable.
The claimed performance certainly seemed to be there, although that may be part of the "passenger" feeling. My car suffers from pinking at anything much over 4500rpm, I couldn't detect any pinking on the G56 car and it pulled cleanly right up to the rev limiter at about 6000 rpm. As for the sound of the absorption exhausts, a low rumble, not annoyingly loud or raspy at all, like 1/4 of a big Yank V8, which it is really. Terence said the standard ECU is able to adjust itself for the G56 Stage 1 kit and does not require a remap, although they are looking into that for future developments. I was surprised to hear that the engine runs very rich at the top in standard tune, I always assumed it was weak, hence the pinking but that's a result of heat build up from the restrictive standard exhaust I am told. The stage 1 kit improves the breathing and mixture through the rev range,.
The inlet filter assembly doesn't look far removed from the original round Morgan one, other than the scoop. Terence insists it performs better than the standard item and helps with the overall performance gains of the kit. The exhausts are larger than the originals but don't look out of place to me. They look well made, come with new mounting brackets and the production ones will have larger, stronger mounting rubber bobbins, another problem solved? The tail pipes on this development car are just cut at an angle and are a bit sharp. I suggested a rolled end like the standard ones have, less chance of them biting your leg. The polished stainless finish is not a problem and black heat shields should be available as well.
Terence said they have had a problem with their supplier but will have this resolved in the next few days, so the kits should be available very soon. I have "expressed an interest" and await to see when they are available. Garage 56 were happy to talk about the kit and answer any questions I had, they seem like a good set up.
geof569 #259200 12/03/15 06:01 PM
Good feedback ..many thanks!
Neil
planenut #259242 12/03/15 08:29 PM
Thanks for this 'avant première' revue, planenut, well done thumbs I will observe a little how they perform & feedbacks....and probably also jump on that train flag
Cheers,
Georges
planenut #259354 13/03/15 12:19 PM
Some more photos of the G56 Stage 1 kit.
geof569 #259444 13/03/15 06:30 PM
Wonder if you can see straight through the G 56 exhaust? I guess there is still a catalyst in the system. I have a 2012 and it "Had" three awful baffles in each pipe. the baffles are now in the scrap heap and I can see daylight at the end of the pipe. It was a really ugly job to remove them, but now I can see daylight at the other end. Its a little noisier but the headers don"t glow anymore. I did however leave the Cats in place for now.
geof569 #259623 14/03/15 02:06 PM
That is exactly what I did, I wonder if G56 will just sell the air cleaner on its own as my exhaust is black with no baffles.
