5 members (Graham, G4FUJ, Craig Jezz, Grumpy2, TBM, Krossek), 187 guests, and 45 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
timbo #258220 08/03/15 07:49 PM
It certainly can be rebuilt and if you are of a mechanical mind and don't count your labour, you can not only cover your costs but actually make some value too.
I'm rebuilding a 65 4/4, parts for which I've been collecting for about 10 years, if I get it professionally painted will still cost less than £5k.
Cheers
Mike
Mike Hughes
1969 4/4 competition (ST170)
2008 +4
1962 Vitesse 6 Formosa
1959 Peerless GT2
timbo #258221 08/03/15 07:54 PM
To me it looks more like a selection of parts, there doesn't appear to be a chassis.. Given the uncrumpled state of the fronts wing etc, it doesn't appear to of been a accident..
Maybe a restoration was started but never finished..
The wheels would suggest 82-92, however they would of fitted on any earlier morgan, as they are just VW ones quite easy to get hold off, however headlight pod position means it must be post 1969..
timbo #258232 08/03/15 09:48 PM
It's great to be sentimental about saving every Morgan but realistically with this one, unless it has a special history that makes it worthwhile saving, just what is the point? Restoration costs will far exceed the value of the car and looking at what is left of it, what will remain original?
timbo #258247 08/03/15 11:26 PM
Pass us the 'T-Cut' I am sure it will rub up OK!
Or is it another project for Wheeler Dealers?!
Keith
timbo #258267 09/03/15 07:20 AM
Yep some nice cars there
John V6 #258295 09/03/15 10:20 AM
I like the colour! (pale primrose, not he iron oxide part)
Andreas
+4
timbo #258297 09/03/15 10:32 AM
This is what happens if you don't keep up with squirting a bit of ACF50 along the wing beads
timbo #258310 09/03/15 11:54 AM
Depending on what parts are included it COULD be a decent project.
Also the asking price!
Paperwork would make reg a bit easier too.
The real cost inflater is labour so if you are hands on then you only have to put a price on your own time, and that is effectively offset by the enjoyment factor.
With a Morgan even spraying is possible as the panels can be done individually PROVIDED safety breathing kit is used! Failing that pre-paint prep can be done and take the bits to a sprayer to finish.
Stewart S #258321 09/03/15 12:47 PM
1972 4/4 2 Seater
timbo #258326 09/03/15 12:59 PM
I always wanted a 4 Place carcass to use only the back seat and rear axle as a sitting chair in my garage. This one is a bit too far away.
Cheers,
Mark
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
