1 members (M3WMW),
224
43
Topics49,911
Posts838,152
Posts: 1,113 Likes: 17
Posts: 1,113 Likes: 17 |
Hi, With my 79 4/4. I have an electric problem.
The car refused to start and just a clicking noise was heard when I turned the key.
I thought it might be the solinoied so I changed that.
Now none of the electrics work and the ignition light does not even come on.
However there is power as there is a voltage reading on the solinoid and the battery.
Any idea what it could be? Thanks, William
Posts: 4 |
Sounds to me like you either have a duff battery William, (How old is it??, if over four years change it anyway, false economy not to).
But if the battery is OK maybe a bad earth connection against the bodywork/chassis or bad connection from the battery to the starter motor. Check the battery connections are TIGHT and smear with a light coating of vaseline.
Can't see it being anything too serious if it was starting OK a few days ago, but I am NOT really an expert to be honest..Are you in the AA or similar??
Incidentally, for anyone who stores their Moggie for any length of time (over two weeks) I would recommend a good battery conditioner such as an optimate,(around
Hi, Was thinking about the battery. I will be away up north fishing this weekend but on Monday I will try the battery in my 87 4/4 in it to see if it works.
The thing is that nothing works not even lights.
If i put a test light on the battery it goes on...
The car isn't mot'd and I am in Norrich Union rescure which does not cover that Morgan, just my one.
William
Posts: 7,935 Likes: 133
Posts: 7,935 Likes: 133 |
William,
Did you find out where the problem was?
Simon
