5 members (+8Rich, gomog, sewin, Ricosan, CJB), 233 guests, and 131 robots.
+8Rich 75
Topics49,868
Posts837,651
Moggo
Drive on the Wild Side
Originally Posted By Peter J
Originally Posted By Chunky4/4Racer
Peter talk to Henry
The scuffs were something I raised with Morgan when I first looked at the car. It looked as though they had sorted it out, but the first time I washed the car the scuffs re-appeared.
Better the plastic than the paint! But yes, I'll talk to Henry.
l
Peter I had scuffs on the paint protector by the door on the wing. You can polish it out using McGuires plastic polish, just apply a bit at a time and rub in a circular motion reasonably hard, may take 2 or 3 attempts but the will go. cheers
Adrian
i have used this on boats sprayhoods and had started to use it on the scuff marks on the mog to great effect
renovo
Pete
3M do a spray on plastic film.
There is a video on Youtube showing it being applied.
https://www.youtube.com/watch?feature=player_detailpage&v=fi3hJYmtKR4
There are other videos in there too, and one shows how easy it is to peel off, similar to the sheet film normally used.
The 3M spray looks straight forward but these videos always make a product look easy peasey
Mine has this on it fitted by BHM when I bought it.
http://www.armourfend.co.uk/
MG owners club used to sell it by the box.
FOLIATEC.com
Bob smile
E
E
Hi Guys
There has been a fair mount of TM topic activity on Stone Chip Protection film for paint work. I have just purchased a kit for my 2006 Plus 4 Wide body.
I looked around a lot of solution options (dealers and third party suppliers). Based on specification and cost I settled on Premier Paint Guard (PPG) and dealt with the owner Dave. He could not of been more helpful.
Their web site give a good idea of the span of their service (including Morgan) .
http://www.premierpaintguard.co.uk/morgan.html
I bought the fully patterned kit of Specification: 3M Paint Protection Film SGH6.
Front wings, Radiator Cowl, Running board "edges" (because I have tread strips each side) Rear Wings.
I also bought the Bonnet Strap protector.
Application kit- I would strongly recommend you buy this. It contains instructions, tips, Fluid concentrates for floating the plastic into position etc
A careful read of the instructions and tips (important to follow), a little patience and doing the easy panels first(eg running boards},it took a total about 3 hours. -
The other advantage is that, in the event a panel of the 3M material gets damaged in use PPG will supply panels individually.
Anyway I am really pleased with the outcome and cost.Real value for money
The bottom line is that for a total cost of £152 and 3 hours enjoyable work my car has the full 3M film protection on all leading surfaces.
Dave will also quote for fitting at his location or traveling to yours. Again, very very reasonable when compared with other provider quotes I obtained.
My recommendation is that if you are thinking about going for stone chip/paint protection, check out Premier Paint Guard
E
E
See a 3M comparison chart between 3M Venture Shield and 3M Scotchguard SGH6
http://ppffilm.com/paint-protection-film/#comparison
