9 members (IcePack, TBM, Image, MATTMOG, chanteclair, Tom Sayles, CJB, +8Rich, Moggo),
259
78
Topics49,868
Posts837,631
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Hello, I suggest you to remove the air filter box and replace it with an open air system from K&N. I fitted this system on my 2009 4/4 Sport ad it works well. If you want I will send you some pictures D'Herde Bart Thanks definitely interested Just a bit concerned that an open induction will pull through hot air from around the engine The hotter the air , the less oxygen, the less efficient the engine should I be concerned?
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Does not effect mine but if you are going at a fare old speed then the amount of cold air getting into the engine bay via the grill and under it should rule that out but you wont know till you try . My oil temp gauge moves up when I stop so I know what the true reading is just by looking at it on the move . The magic of owning a mog others think its madness .
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Hello, I suggest you to remove the air filter box and replace it with an open air system from K&N. I fitted this system on my 2009 4/4 Sport ad it works well. If you want I will send you some pictures D'Herde Bart Thanks definitely interested Just a bit concerned that an open induction will pull through hot air from around the engine The hotter the air , the less oxygen, the less efficient the engine should I be concerned? I think so plus if not in the airbox you get more induction noise. Then it depends if you like that or not.
Posts: 1,653 |
Rapide engineering do a clever kit for the Sigma 4/4, makes it cold air induction in a shield.
Cain of Wolfperformance is clever at doing diverted cold air to an induction kit.
Thanks for that - I'll investigate
I got the K&N filter today so will be hopefully getting it into the filter box tonight if it all comes apart OK
Just an update
This evening I swapped the paper air filter for the K&N one. Very easy swap, just had to take three bolts out to lift the filter box clear of the water expansion tank/reservoir thingy whatever it's called - black thing where water goes ( you can tell I dont know much about cars)
Popped the new filter in and took it for a quick drive round a few country lanes and the engine and exhaust is definitely louder, deeper sounding and more rumble
I would not have believed a filter could make that much difference
Posts: 5,210 |
Just an update
I would not have believed a filter could make that much difference So is the sports exhaust being posted back then?!
Just an update
I would not have believed a filter could make that much difference So is the sports exhaust being posted back then?! Ah well , we've got to tinker
Filters do make a big difference
