7 members (Plus Four Guy, BLG83, Ncik P, Paul F, eds, Andy, Bitsobrits), 275 guests, and 76 robots.
+8Rich 76
DaveW 52
Topics49,868
Posts837,634
Moggo
Originally Posted By dherdebart
Hello,
I suggest you to remove the air filter box and replace it with an open air system from K&N. I fitted this system on my 2009 4/4 Sport ad it works well.
If you want I will send you some pictures
D'Herde Bart
Thanks definitely interested
Just a bit concerned that an open induction will pull through hot air from around the engine
The hotter the air , the less oxygen, the less efficient the engine
should I be concerned?
Posting Desperado
Posting Desperado
Does not effect mine but if you are going at a fare old speed then the amount of cold air getting into the engine bay via the grill and under it should rule that out but you wont know till you try . My oil temp gauge moves up when I stop so I know what the true reading is just by looking at it on the move . The magic of owning a mog others think its madness .
Hello,
D'Herde Bart
I think so plus if not in the airbox you get more induction noise. Then it depends if you like that or not.
Rapide engineering do a clever kit for the Sigma 4/4, makes it cold air induction in a shield.
Cain of Wolfperformance is clever at doing diverted cold air to an induction kit.
Thanks for that - I'll investigate
I got the K&N filter today so will be hopefully getting it into the filter box tonight if it all comes apart OK
Just an update
This evening I swapped the paper air filter for the K&N one. Very easy swap, just had to take three bolts out to lift the filter box clear of the water expansion tank/reservoir thingy whatever it's called - black thing where water goes ( you can tell I dont know much about cars)
Popped the new filter in and took it for a quick drive round a few country lanes and the engine and exhaust is definitely louder, deeper sounding and more rumble
I would not have believed a filter could make that much difference
Just an update
So is the sports exhaust being posted back then?! rofl
Roger
Originally Posted By Roger-Cheshire
Just an update
Ah well , we've got to tinker
Filters do make a big difference
