3 members (Jon G4LJW, TBM, cerealsurfer), 273 guests, and 35 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
RichB Offline OP
Seems to be garage time again smile .
After seeing the internals of the Aero Plus 8 rear from Peter’s postings I had a look at the space under the spare wheel on the +4 to see if it could get dirty – and yes it could confused2 . There is a relatively large hole in each inner rear wheel arch – seemingly only to get the wiring to the rear indicators – why so large? Not sure. Perhaps a minor detail, but dust/grit/debris/spray will find its way into the void below the spare wheel – where the petrol pump etc is located. Best avoided.
To fill this I decided to use some rubber cut from an old car mat. Template made in cardboard and piece cut out to shape but about 2mm larger all the way round and a slot for the wiring.
This was then inserted into the hole and is quite firmly held in place.
Now over-sprayed with Dinitrol 4941 to make it look neat.
Previously I had tightened up a slightly wobbly gear knob (not a euphemism…. nono ). I didn’t want to damage the bottom collar (or buy a new one! spend ) and found that winding electrical insulating tape several times around the bottom collar, with the last winding a little ruckled, gave more leverage (a slightly greater diameter) but way better grip so that it undid reasonably easily.
To resolve the ‘wobble’ I took the aluminium centre column and plastic insert off (visible in the centre of pic below), wound some insulating tape around the screw thread of the gearstick itself to ensure a tight fit of the plastic centre cap and centre column.
Then replaced the three securing grub screws, did them up tight using Loctite – and replaced the top part of the gear knob and lower collar (again with insulating taps to help grip).
Now all’s tickety boo. Will have to take it out for drive tomorrow – just to make sure (again) drive
+4 GDI Connaught Green, 2014
Magnolia
Black Rat
Black Rat
Richard is it the knob that unscrews or the collar ?
Keith
2013 narrow bodied + 4 Ruby.
RichB Offline OP
Keith - both unscrew from the static centre column (the three grub screws hold this in place). But it seems to me it is best to undo the bottom collar first. The top, the 'main' gear knob, is then loose and may be unscrewed very easily. Just in case I needed it, I marked the centre collar so that I could replace it in exactly the same orientation so when the top was replaced and screwed down fully it becomes tight with the shift pattern insert orientated correctly. Bottom collar then tightened up to it.
Magnolia
Black Rat
Black Rat
Thanks Richard, I will have a go.
Keith
