2 members (+8Rich, DaveK), 322 guests, and 38 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,085
When overtaking another car this morning the engine suddenly felt "dead" with increased vibration.
stopped at home checked that all tyres were true, exhaust fixed, rocking the engine from side to side steady in its engine mounts.
Started it again, when reving it got rough as if not running on all cylinders.
The engine is standard except modified idle speed control valve.
What could it be?
4/4 2 seater 2001 model
Failed coil pack?
Originally Posted By Hamwich
Failed coil pack?
seconded
How do i identify failed coil pack? Is it the lump where all the spark plug wires go?
Not a mechanic only an enthusiast.
E
E
The problem is you only know when a coil pack has failed when you change it for a good one there are some tests that can be done but of limited value.
Fixed a similar problem on a 1992 MX5 the other day and it was the temperature sender that supplies the ECU with readings to decide when to put the electronic chocke on.
It was giving the wrong readings. In that case the simplistic diagnosetics gave 9 flashes on an LED.
On that car there was another sendor to feed the electric fan.
A friend uses one of these with his laptop on older Fords.
http://www.ebay.co.uk/itm/Ford-F-SUPER-d...=item234338644d
It could also be a loose HT lead or a faulty spark plug
E
E
Yes change the plugs and if you can find a friend with a similar engine get a loan of their plug leads for twenty minutes. That would check the possible inexpensive route.
Make sure the leads are well on to the plugs. Had similar problem when changed cam cover gasket.
Keith
Thank you all for good advice.
I pulled the spark plug cables and found water round the spark plugs.
Probably from too enthusiastically washing.
After drying up I found the rough running still remained but to a lesser degree.
A new inspection revealed lots of rust round the spark plugs closes to the bulkhead, could hardly see the hex head!
After scratching and vacuum cleaning round the spark plugs I also cleaned the spark plug cables which were covered in rust.
New test drive today, problem gone.
A cover over the camshaft cover and spark plug would probably be of great benefit.
I purchased a nice stainless steel cover that keeps most of the water out(and makes the engine bay sparkle), but I would suggest covering the engine when giving a good clean. sunny
Autospecialists Spark Plug Leads cover
Keith
