7 members (Morganmike, piquet, Ian Wegg, Robbie, linklaw, Clipper, Alistair),
337
44
Topics49,837
Posts837,291
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
All I would do with that is a lick of aluminium paint. Nothing more. Lacquer won't stay on very well, it's a hostile environment, assuming the oil gets hot...........
Posts: 517 |
Salty air, cow poo etc the problem down here. Grass in the middle of the road will polish it up for you.
Titus
2007 +4 4 seater 2017 Mini Cooper 2007 VW Camper 1996 Honda TRX300 2012 Husqvarna 216
Posts: 4,896 |
Sorry for the delay getting back to you all to respond to your comments, but as Budster said I popped over to him for a chat a round trip of 38 miles I managed to avoid any puddles to avoid getting the car dirty. The delay was I had to check it still had a clean bottom  I am not going  , just a bit of a clean up as I have done nearly 2K miles through the winter  (more that I suspect some of you do in a summer)  on the holy grail trail of the ECU upgrade by the way it is performing very well. MPG as measured today is a reasonable 28mpg, after 134 miles some of which had some serious blasts of acceleration. The mpg readout is currently showing 31mpg. So the drive to Budster and back was a bit of a bumble. When I cleaned under the arches and the wheels the other week I greased up the pins, and turned the AVO's up one notch on the front to 5 clicks, what a difference a click makes, I think the pins needed a good grease as it was 800 miles since the last one. Anyway back to the engine bottom, were's DaveW I am sure he can give me some sensible advice even if you lot can't.
Adrian
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
A sump impact guard would be the way to go if you are seriously concerned this make have been caused however on previous gravel road Useage.
Posts: 582 |
Posts: 4,896 |
Don't tempt me or I might order a Black Death Star and go over to the dark side, and join the Emporer Peter J.
Adrian
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Nothing wrong with some post winter TLC. I experimented on my exhaust yesterday..... Pepsi and a scotchpad. Worked well on the stainless. Didn't use it on the polished tailpipes though. Also tried it on the cast exhaust manifold. Worked well there too.. Will revisit manifold again when I have more time. May even polish the exhaust...........
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
A sump impact guard would be the way to go if you are seriously concerned this make have been caused however on previous gravel road Useage. Indeed... the car in question did go to North Cape. Some really rough surfaced roads there.
Don't tempt me or I might order a Black Death Star and go over to the dark side, and join the Emporer Peter J. Always space for a new Knight...!
Posts: 4,896 |
A sump impact guard would be the way to go if you are seriously concerned this make have been caused however on previous gravel road Useage. Indeed... the car in question did go to North Cape. Some really rough surfaced roads there. I have the photos from the trip and surprisingly the roads don't look too bad, although I think one of the cars suffered a broken light from a thrown stone.
Adrian
