8 members (Clipper, Morganmike, PaulV, RichardV6, Zach, JoeSpeetjens, DCH, teknome), 355 guests, and 92 robots.
+8Rich 78
DaveW 52
Topics49,867
Posts837,612
Page 7 of 9 1 2 3 4 5 6 7 8 9
RedThree #606870 07/12/19 08:54 PM
Originally Posted by RedThree
Originally Posted by Jays
Blimey Calum! Thank god Morgan didn't design the car with two rear wheels!
I have seen the Speedbleed nipples years ago and heard that they were very good. have never actually used them though.
Are the bleeder nipples a standard size and what would that size be? I am in the middle of changing the rear tyre and really appreciate the write up Calum has done. Many thanks SIR!
P Dron #606963 08/12/19 03:46 PM
Here is perhaps a better question, who makes the rear brake assembly?
In knowing that then it’s associated parts should be fairly easy to source.
P Dron #606965 08/12/19 04:00 PM
Michelin CrossClimate Plus has been brilliant.
Managed to find a note of the speed bleed nipples I fitted. They were marketed as Goodridge Speed Bleeder Nipples but probably came from this lot;
for the front calipers it was 4x the 10x1mm size
and for the rear 1x the 7x1mm size
and you're very welcome!
P Dron #607003 08/12/19 07:11 PM
Got it, thanks for the info Calum.
RedThree #607194 09/12/19 10:43 PM
I would add that I take no responsibility for skint knuckles, cursing, swearing, general bad language and broken marriages. Other than my own of course.
Speedbleeder in the mail now and tyre out and sitting in the boot of the mini along with the new tyre going to shop tomorrow to get it changed.
OEM tyre is not a symetrical trad pattern and the new one is. Might help.
P Dron #607699 12/12/19 06:09 PM
Tire installed, new vulgar words found, still don’t understand why MMC used an asymmetrical tread pattern.
Tip, save yourself some grief and mess by having a plug and cap on hand to cap off the brake line and plug the hole in the backing plate.
Question: is there a torque spec for the axle nut?
P Dron #607711 12/12/19 07:15 PM
No torque spec, just take it to seriously tight then tighten till a castellation lines up with the hole in the spindle.
Used a torque wrench once to get an estimate of the torque required and it came to about 180ftlb.
P Dron #607715 12/12/19 07:26 PM
I used a 24” crescent wrench on the nut and it took some real effort to loosen it so I did not want to over tighten it when putting it back. Thanks Calum.
You don't need to disconnect the brake line to take the rear wheel out, there should be enough slack if you undo the p-clip on the swing arm, then when you pull the wheel back remove the brake backplate and lay it on something of convenient height under the car.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
