12 members (deano, Mark+4, Alistair, BobtheTrain, DaveW, hillclimber, IcePack, Morganmike, Socalm3w, TeddyAds, sewin, MATTMOG),
349
60
Topics49,859
Posts837,517
Posts: 145 Likes: 1
Posts: 145 Likes: 1 |
Is there anyone out there that can tell me the correct thermostat for a +8. I have just taken mine out cos its running too cold and (of course )previous owner has drilled extra holes to increase flow.The thermostat is marked for 82c and 180f whatever they are,is this correct? people round here are telling me its too low a temp. any info/assistance appreciated
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
The 82 and 180 refer to temperature in Centigrade & Fahrenheit. I am sure someone out there knows the correct temp thermomstat to use
Posts: 145 Likes: 1
I was being a little droll there ,I thought,although it must be 30 years since I used Fahrenheit.
Posts: 921 Likes: 1
Posts: 921 Likes: 1 |
Chris what year is your +8?
Posts: 145 Likes: 1
1995 , 3.9 I should have said that originally I guess
Posts: 18 |
87 C or 92 C dependant on engine type ,early non injected units are happy to run cold but later injected units need to run at there optimum temperature. The issue with rad fan duty cycle can be down to year build. However, be careful not to be sucked down the 'iv'e got to stop the rad fan running' road because you won't. +8's run HOT, as long as your fan only cuts in when you stop I would not worry too much. However, always carry a spare rad fan relay in the car, the duty cycle on these is very high, as is the failure rate.If you dont know the relay Cereal or Oldtimers can help.
