6 members (AlyMatt, TrickieDickie, IcePack, David_E, PaulJ, DaveW), 280 guests, and 93 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Page 6 of 11 1 2 4 5 6 7 8 10 11
For a number of reasons I wouldn't.
If you go wider you'll have to run lower profile tyres, or offset the wheels further out. Don't know about Austria, but it's not permissible to have wheels/tyres protruding beyond the body line (wings) in the UK. Increasing wheel offset puts a lot of extra strain on suspension components.
Sidewall flex is a part of the suspension.
Plus you'll mess up the handling...
camera when you get your 4/4 smile
Part of the fun of the 4/4 is the handling- the narrow tyres are a big part of that. Stick with the size- play around with different rubber.
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
JB62 #267929 17/04/15 08:06 AM
+1
JB62 #267949 17/04/15 08:48 AM
That is very much the simpler, but true, answer!! thumbs smile
+1. Enjoy your new car
If you do decide to up.the width, and as the guys say, there is no need, you stand a good chance of 195s fouling the wings.
Rog Offline
Absolutely right about spoiling the handling but I’m a superficial poser type of Morgan owner myself. I’m not brave enough to eke out the last bit of road holding. I just love the look of the “balloony” 185’s on my 4/4 (I think they may offer a little extra comfort as well).
PS – I think you can only get away with 185’s on post 2005 cars but 195’s would be too big for mine.
Roger
Not yet a MOG owner, and have to decide between a +4 from -97 and a 4/4 from -06. Since I have the legs of a ballerina (i.e. to long) I must chose the car with the best/largest internal space.
Have been told that the above cars shares the same width and length in the "cockpit" ??
Challe W
4/4, 2006
ChalleW #277085 26/05/15 05:04 PM
They both have pretty much internal dimensions, but you may find a difference between the models in the extent to which the seat slides back. Try both and see which you prefer, but if it were me, I think I'd go for the younger car as that will be a long door model and should be easier to get in and out of. The '97 might also be a long door model, I'm not entirely certain when they made the switch.
ChalleW #277106 26/05/15 06:26 PM
Welcome to TM. It's probably on the cusp with being a long/short door model. Generally, the the cockpit is the same internally but depending on age there will be differences if you compare an old model with a newer one. Others on here will give you more information on that. You need to drive both as they are different in character and I would suggest you search based around the characteristics of the model you prefer. As they say, the car will choose you!
Roger
