6 members (TBM, John V6, Rex_tulips, JohnHarris, Robbie, GrumpyPa), 484 guests, and 38 robots.
+8Rich 69
Adam12 69
John V6 52
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,544
Members9,215
Page 3 of 3 1 2 3
The Austrian #267901 17/04/15 06:31 AM
Formerly known as Aldermog
Originally Posted By The Austrian
Matty, did you drill a hole on each end of the crack to stop further cracking by notch effect? If not the crack will slowly expand further even with a supporting plate.
Exactly: probably also worth epoxy bonding the reinforcement plate to the body so that structurally it becomes part of the body.
Matty #267987 17/04/15 10:21 AM
I'm wondering whether it might not be a good idea to transmit some of the load and vibration down to the chassis rail, rather than adding to the weight being carried by the aluminium skin? Forgive the rubbish sketch, but would it be worth considering something like this that could be bonded with something like Sikaflex to the chassis rail - always assuming it's reachable, of course.
Hamwich #267996 17/04/15 10:56 AM
Good plan...
Of course what they should have done is put a plate welded to the chassis rail behind the alloy skin so that the exhaust bracket is bolted through the body to the bracket.... banghead
Matty #268023 17/04/15 01:35 PM
Matty Offline OP
Haven't drilled the holeyet, until Morgan have replied.
I agree ref the chassis plate. May be able to use seatbelt fixing point.
The Austrian #268044 17/04/15 03:10 PM
Yes you have to use a magnifying glass and drill the end of the crack to give it a rounded stress-point free end. Thats what they do to planes I beleive. I am sure MDH knows more about this!
I have heard of them cracking before. Hence why the g56 kit uses an uprated exhaust mount.
Id the crack coming from an echaust mount hole?
I wonder if rubber grommets/ washers would be ki der to the interface?
Did mmc fix your light cluster?
Peter J #268045 17/04/15 03:13 PM
Originally Posted By Peter J
Good plan...
That would have required exacting tolerances between the skin fabricating and the chassis!
The philosophy is to bolt onto the thing which is bolted onto the other thing which hangs off that thing which is stuck onto this thing.
Ah...how Morgan.... banghead
Matty #268056 17/04/15 03:50 PM
To be fair I think my aluminium shell is on the whole a beautiful piece of design and craftmanship
Matty #268196 18/04/15 08:26 AM
Matty Offline OP
My concern is the ongoing vibration so I think some method of stopping the vibration is paramount.
The Austrian #270101 25/04/15 04:33 PM
Matty Offline OP
I was waiting for a response from Morgan ref the crack which is over 3inches long, before I drilled any wholes in the body. However none has been forthcoming so I have drilled and replaced the plate with additional support holes. The whole area is now much stiffer. Interestingly the exhaust bobbins on this side of the car appear to be much stiffer than the drivers side. The only real answer will be a chassis mounted bracket.
Page 3 of 3 1 2 3
