5 members (Morganmike, SteveT, teknome, ScotiaSteve, Gordon D), 484 guests, and 124 robots.
Sagging Hood
Topics49,859
Posts837,481
Peter J Offline OP
Formerly known as Aldermog
Originally Posted By Chunky4/4Racer
I also agree with never use wd40 it's rubbish. I use Innotec Deblock. This is brilliant
http://www.innotecworld.com/products/greases-lubricants.php?productid=84
Innotec are in Churchfields trading estate 5 miles from me. I think a trip there is called for...they have other interesting stuff too....
I'm not sure they sell to the public but by all means try mate. If they don't sell to you, then we can sell you a tin when your next in
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
Peter J Offline OP
I can but ask....
Go buy yourself a brake caliper pin punch set Peter normally two in a set 5.5mm and 6mm
or a triple set sizes 3 4 and 6mm
I take it the calipers do use a standard size pin?
At least they'll have the correct depth ability.
Mark - No Longer driving
If you do it with the hose connected keep on eye on the brake fluid reservoir as your push the pistons back....
My HiSpec calipers have pins which are secured by R clips, so I have no need of a caliper pin punch set. The thing is, though, is that they might stop making them. And then I might buy a car that had calipers that need them. And then where would I be?
There's always a reason to buy more tools.. smile
When pushing the piston back in brakes I always open the bleed nipple as it is easier and removes a portion of the worked/cooked brake fluid rather than shoving it back up the hoses.
Peter J Offline OP
Given the car has ABS disconnecting brake hoses isn't something I want to do. nono
Given the radiator header tank is immediately above the brake master cylinder removing fluid is going to need a syringe and a plastic pipe. confused
Yes, buying a pin push set makes a lot of sense. More tools... joy
Oh come on Peter, get the bonnet and wings off then there's plenty of space!
You can always then get in the nooks and cranies and give them a good clean and waxing!
Regarding the WD40:
I consider most of these aerosol oils equal because they mainly are kerosene, naphta or iso-paraffin or equal stuff with only minor differences in chain-length and boiling-point. But curious as I am, I had a look at the datasheet of Deblock. That is really different. It contains 10-25% Aceton, which explains the better penetration capability that you have experienced. Thanks for the advice.
Regards
Ex-Roadster 3.7, now P6
