0 members (), 333 guests, and 43 robots.
+8Rich 93
John V6 49
Posts837,990
#270053 25/04/15 10:00 AM
Hi
I;m seeking some advice relating to the Carbon Filter on my '99 3.9 Plus Eight,
I was thinking of replacing this item, then thought "Does the car really need this kit?"
so my question is ,
Has anyone else removed this thing which sits like a black post box on top of the Passenger footwell, If someone has removed it , what is involved & how is the tank breathing managed
Thanks for any input
Alan
Isn't this part of the evaporation system for emissions control?
If so it is probably monitored by your engine management system. Which system do you have?
My 2002 plus8 has Gems management that does this.
I did once get the warning light on and my OBD analyser showed a evap fault linked to the cannister.
It cleared without issue and has not come back. Probably caused by me and over enthusiastic throttle when cold!
Try checking Gomog site for info.
Thats one of my concerns , Mine is the 14CUX injection system
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
Just for info the normal issue with the GEMS cars (I had a 2002 +8) was overfilling, as the carbon canister is next to the fuel tank it gets fuel in it when the tank is overfilled. When the purge valve opens the plenum gets fuel instead of fumes and when the unburnt fuel gets to the Lambda the ECU tries to weaken the mixture and when it reaches its limits it stores a multiple misfire code and pops the light on. A few engine drive cycle clears the light but the code stays there and needs clearing with a code reader, does no harm being there so nothing to worry about.
BR Colin
That's what I think happened to me!
Going for a long run I may have "squeezed every drop" into the tank.
I tend to hold back these days and no faults being flagged up since.
I cleared the code with my code reader.
I also try to avoid jumping into the car, starting, blast off ....to try to allow the system to clear as the engine warms up without high demand for fuel.
