4 members (BobtheTrain, IcePack, Zach, Rog G), 238 guests, and 42 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
#270623 27/04/15 12:49 PM
Marcus Offline OP
I recently purchased a 1970 4/4 from the original owner. He gave me the chassis number which is on the title also. I wanted to find it on the car and was told it was stamped on the front crossmember on the passenger side. I took a look and couldn't find it there or on the member under the seat. What am I missing. There is no rust on the car and it is the original frame so where else should I look? Thanks in advance. Marcus
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
1988 Porsche Boxster
Marcus #270625 27/04/15 12:59 PM
You need to slide the seat right forward (and if the seats allow fold them forward too). It's the rail to the rear of the seat not the one in front of them.
The number stamped (more often than not) on the bonnet flange should be the last four digits of the engine number.
Marcus #270642 27/04/15 02:41 PM
At some stage Morgan changed where they stamp the chassis or VIN number and on the current cars it is stamped on the passenger side front crossmember where it is meant to be seen by peering through the screen!
Marcus #270646 27/04/15 02:52 PM
Marcus Offline OP
Richard,
I'm new to Morgans and am sort of perplexed. My car does not have sliding seats. It has wooden platforms that sit between the steel members with a bladder on the top of the wood for a cushion. Seems rather crude but effective although there is no way to adjust the seat position. I've looked at both steel members and have found no numbers. We are talking the passenger side aren't we?
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
Marcus #270651 27/04/15 03:03 PM
Take the easy way out. Get yourself a set of stamps and stamp the frame number you've been given onto the cross member somewhere where it's easy to get at. End of problem.
Marcus #270654 27/04/15 03:16 PM
Originally Posted By Marcus
Richard,
Mine's on the driver's (right looking from the rear of the car) side on the cross-member behind the seat.
1972 4/4 2 Seater
Marcus #270664 27/04/15 04:12 PM
Marcus Offline OP
I've got a left hand drive car. Does that mean that it is on the right side of your car which would be on the driver's side of your car? I've looked there already. Marcus
Mark
1970 4/4 Morgan
Two '53 MG TD's
1949 MG TC
Marcus #270746 27/04/15 08:20 PM
Marcus ,
At that time the stamping of numbers was not very deep into the metal of the chassis, so even if it has not rusted, a few coats of paints will cover the shallow marks very easily indeed.
On my two of my +4s the number was stamped on the top of the crossmember on the driver's side (on a RHD UK car) but both were very faint and I had to search a long time to find them. On the other one it had been re-chassied so many times that the original number had long been lost, and like Tim suggests, I bought some stamps and did my own. If after searching really diligently for a long time , you really don't find it, then follow Tim's advice and do it yourself.
Andy G
1999 +8 , Indigo Blue.
Marcus #270761 27/04/15 08:57 PM
Marcus, I have a 1969 4/4 and I've never been able to find mine either!
Must have another look sometime. My seats were replaced with 1970 plus 8 buckets so they slide. You have the original bolster with blow up cushions, now quite rare I think but the cushions and wooden bases should be easily removable. Let us know where the chassis no. was when you find it!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Marcus #270786 27/04/15 11:09 PM
Passenger side for you Marcus.
