7 members (PeteMalvern, Rog G, mph, Grumpy2, Morganmike, MATTMOG, OZ 4/4), 304 guests, and 47 robots.
John V6 71
DaveW 67
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,991
RedThree
Mine also has the grease nipple fitted, twice a year I give it about 10 pumps of JCB high pressure waterproof blue grease. It runs as quiet as a whisper at all speeds and loads even down to 2000rpm
The hole in the bell housing is about 1-11/4" dia. This is not critical.
To get a datum measure the centre of the compensator at the top through the steering rack cut out and transfer the measurement to the bottom.
Hope that helps.
Couple of photos showing a compensator complete with grease nipple packed with grease while being assembled on the bench and a compensator housing showing the cutaway on the top for the steering rack and the hole that was drilled for access to the grease nipple.
Hope this helps.
Grease packed compensator c/w nipple
Drilled compensator housing
Thanks guys for the information and pictures. Sounds like a must do.
LarryS Offline OP
Thanks, already had the compensator replaced. I'm pretty sure it's a chassis type noise. I squeezed some heavy grease into a few likely locations. I'll see if that made any difference. LarryS
Hi
Check for cracks around the exhaust mountings
