7 members (Bishmog, Heinz, Burgundymog, GrumpyPa, yrr13, B&C Morgan, Grumpy2), 375 guests, and 41 robots.
John V6 69
DaveW 64
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,348
Posts813,084
Members9,212
aeroed, DJC, James Mc, JimWhin
Mine also has the grease nipple fitted, twice a year I give it about 10 pumps of JCB high pressure waterproof blue grease. It runs as quiet as a whisper at all speeds and loads even down to 2000rpm
The hole in the bell housing is about 1-11/4" dia. This is not critical.
To get a datum measure the centre of the compensator at the top through the steering rack cut out and transfer the measurement to the bottom.
Hope that helps.
Couple of photos showing a compensator complete with grease nipple packed with grease while being assembled on the bench and a compensator housing showing the cutaway on the top for the steering rack and the hole that was drilled for access to the grease nipple.
Hope this helps.
Grease packed compensator c/w nipple
Drilled compensator housing
Thanks guys for the information and pictures. Sounds like a must do.
LarryS Offline OP
Thanks, already had the compensator replaced. I'm pretty sure it's a chassis type noise. I squeezed some heavy grease into a few likely locations. I'll see if that made any difference. LarryS
Hi
Check for cracks around the exhaust mountings
