Morgan Aero 8
1 members (RichardV6), 251 guests, and 40 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
Page 3 of 5 1 2 3 4 5
dodgyken #273305 08/05/15 02:10 PM
Originally Posted By dodgyken
You should try filling a Supersport - not only does it suffer the same short neck problem but the rear wing means you have to hold it at an awkward angle - usually with the other hand underneath.
First time you go to service it, tell the guys to check if the pipe no. 12 is not full of gasoline.
http://www.aero-racing.co.uk/partsbooks/supersports/fuel%20system.htm
nick w #273506 09/05/15 06:21 PM
Neilda Offline OP
Originally Posted By nick w
This may be a longshot Neil but I had very slow filling on my 44. I noticed that inside the filler, once the cap is removed, is a perforated alluminium ring. I think this is connected to a small flap that closes behing the hole. I noticed mine was at a 9 oclock position. I simply rotated the ring using a small spike, it moves easily, till the flap was hinged at the top, 12 oclock. My filling problem was instantly solved. It sounds weird but have a look, if the filler on a plus 8 is the same, you will easily see what I mean.
Nick
Nik - that was it! Brilliant.... thank you. smile
It's not perfect, but I can now squeeze half a trigger in combination with the Jenks patented 12 o'clock manoeuvre.
It's a super fast fill compared to the previous 5% squeeze. Much, much better.
+8 4.8
Neilda #273546 09/05/15 09:04 PM
Excellent news Neil.
Nick
Neilda #273576 10/05/15 07:30 AM
Formerly known as Aldermog
I will check mine!
Report to follow!
Peter J #273597 10/05/15 08:53 AM
I checked.
It had moved...the flap piviot was at 7 O'clock. Interestingly the car had become increasingly difficult to fill, blowing back a bit of fuel as it became full.
Slid it back to 12 O'Clock. It is very easy to turn, finger pressure is enough. It will be interesting to see if it is easier to fill. If it is then a spot of Epoxy may be indicated.
Could this be the root cause of all the filling problems reported? It certainly explains why dome cars are easy to fill, some are not and some change...
Neilda #273598 10/05/15 08:58 AM
Might be worth experimenting.......1 oclock might be even better?
Nick
Neilda #273601 10/05/15 09:04 AM
Somebody nice always talks to you when you fill up,I really like that about the Mog...
Em
Neilda #273622 10/05/15 10:34 AM
Mine was at 9 o'clock so moved it to the recommended position. Had a close look at the flap though and it doesn't seem to obscure the fill in any position and the pump nozzle should clear the flap completely when inserted. So not sure what affect it will have but time will tell!
Martin (Deano)
Neilda #273671 10/05/15 03:55 PM
Neilda Offline OP
I didn't look closely, but perhaps the vent holes are cleared at 12 o'clock? Whatever, it most definitely makes a difference on mine.
+8 4.8
Neilda #273738 10/05/15 08:37 PM
Drive on the Wild Side
Perhaps it's time to count how many vent holes you have hide grin2
Adrian
