Topics49,901
Posts838,046
Posts: 62 |
Well, I haven't tried anything yet that was suggested but I'm amazed at how many folks have or had a whistle. It seems as if the noise is more towards the cockpit and almost seems as if it is under the dash. At least now I have something to work with. Can I assume that the gap that Dave is talking about is between the bonnet and the tub? It appears as if most models have had this noise so it could be that it is a problem basic to the body design. Hopefully I'll be able to try some of these ideas out in the next couple of days. Any other ideas would be welcome. I sure would like to get the wife out for a spirited drive with no noise.
Mark 1970 4/4 Morgan Two '53 MG TD's 1949 MG TC 1988 Porsche Boxster
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
No, between the headlamp rim and headlamp unit. Pop the rim off and stick the tape to the headlamp. One screw per side. Bad whistle on Mr Bumble until I did this.
Posts: 4,896 |
A Morgan whistles when it's happy  , no seriously DaveW is quite correct.
Adrian
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
A Morgan whistles when it's happy  , no seriously DaveW is quite correct. What tune does it whistle?
Posts: 2,583 |
" Mad Mogs and Englishmen" Who let the Mogs out How much is that Moggie in the window Morganleid Morgen - pier Gynt Hopefully not - Morgan has broken.
[ Hopefully not - Morgan has broken. [/quote]M3W Tune.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
The whistle in my car went the moment I took SWMBO's false teeth away.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
You forgot; I'm getting married in the Morgan.
Peter, where does the vicar stand?
