8 members (JohnHarris, Mats, Montegue, stumog, Gordon D, Image, John V6, TalkMorgan), 376 guests, and 82 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
#277058 26/05/15 03:41 PM
My 2013 4/4 developed a squeaky rear near side brake last week. The brakes worked fine so I put it down to dust and assumed it would sort itself out. At the weekend it was still there and in addition it had developed a squeal as I pulled away. Today both squeak and squeal were still present so after a short run I checked the rear near side wheel and it was very hot, too hot to touch. The brake drum was very hot and there is quite a lot of brake dust on the wheel not present on the other three.I think it is a seized brake piston but would really appreciate any other thoughts which may be helpful.
Thanks in advance,
Andy
Laser red 4/4
Red Classic Mini Cooper Sport
Audi TT 2.0 TFSI Quatro
Brum Rum #277062 26/05/15 04:07 PM
It certainly sounds like a seized brake cylinder Andy. All the symptoms are present. Worth pulling off the brake drum and having a good look. You might if you are lucky get away with a good soak in brake cleaner spray.
I'd also check that the handbrake cable is free from the adjuster bracket to the backplate as well. The cable outer can split at the bend to the backplate and the wire inner spiral corrodes and eventually snaps, wearing the inner cable.
Good luck!
Brum Rum #277065 26/05/15 04:10 PM
...or the pad has (partially) separated from the pad??
Brum Rum #277066 26/05/15 04:12 PM
As Jay points out check the handbrake mechanism, this kind of condition is often found to be stiff or part seized handbrake linkage and or pivots. Where cylinders can often be eased by using a large flat screwdriver on either shoe and pushing the shoes back and pistons in alternately to shuttle the wheel cylinder pistons back and forth.
BR Colin
Brum Rum #277072 26/05/15 04:22 PM
The heat is probably from binding brakes either from a sticky caliper or pads.
Maybe debris picked up and the disc rubbing it?
I had similar on a car a few years ago. A clean up failed as an easy first fix. It was a seizing caliper in the end.
Symptoms were exactly as you described.
I tried repeated brake/ pushing pistons back but to no avail.
Replaced the caliper in the end...
The problem was a damaged rubber seal allowed water to get onto the piston causing slight corrosion.
sospan #277089 26/05/15 05:15 PM
N/S rear? Caliper?......it's a drum brake with shoes not a disc with pads, car is a Trad not an Aero based.
BR Colin
Brum Rum #277134 26/05/15 07:41 PM
My 1990 4/4 had just this year a major overhaul of the rear drums: more than 30% difference is a dutch MOT issue, so after installing a servo, making new copper hoses, new 4 caliper pisons in front last year, now I have also new brake cylinders and brake pads at the rear. For a 1990 Morgan, it's not that odd! But for a 2013 Morgan? Isn't that a little too soon??!!
Ruut Bianchi
Brum Rum #277137 26/05/15 07:44 PM
I would suspect the handbrake cable first on a two year old.
Brum Rum #277263 27/05/15 01:09 PM
OOOPS!
Just spotted the rear word!
My speed reading is deteriorating!
doh
Brum Rum #277294 27/05/15 03:57 PM
if it turns out to be a seized cylinder its worth checking the other side and changing the brake fluid. A Lesson I learnt from recent previous experience.
Jeff
2009 Black & Tan +4
