Topics49,871
Posts837,680
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
Posts: 8 |
Keep in mind that the factory shroud has a very important job of directing the air around the back side of the cylinders while the car is in motion and the fan isn't running. Without the shroud there is no air movement over the fins around the spark plugs while the car is in motion.
Posts: 342 |
Hi Rog, very nice job, clean work  ...like it...could you post the exact specs and where to order the fan please. Could you already test the fan in skipfire mode, how does it perform?
Cheers, Georges
Posts: 99 |
This reminds me of the cooling fan I fitted to my Harley in Spain. Known as a parade fan, it forced air across the two cylinders preventing overheating during low speed journeys. It worked very well apart from the the fact that the newly created stream of blast furnace temperature air cooked my right leg!
Posts: 1,738 Likes: 56
Posts: 1,738 Likes: 56 |
Keep in mind that the factory shroud has a very important job of directing the air around the back side of the cylinders while the car is in motion and the fan isn't running. Without the shroud there is no air movement over the fins around the spark plugs while the car is in motion. Yes, this was explained to me by Mark Baldwin and finally persuaded me to go with the standard factory cooling solution (even though my engine had never gone into skip-fire mode). Also, it was surprisingly inexpensive at £125+VAT...
Andy
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
Hi bunny Did you fit the kit yourself?
Hi bunny Did you fit the kit yourself? No, it was fitted when the car was at the factory for Centa & chassis 'upgrades'. I don't think it's a DIY job because the ECU also needs to be re-programmed (it turns on the fan at low speeds and when stationary). I guess it should be possible to just install the cowl & fan with a manual switch but I don't know anyone who's done this.
Andy
Hi Rog, very nice job, clean work  ...like it...could you post the exact specs and where to order the fan please. Could you already test the fan in skipfire mode, how does it perform? Smaug This the fan I used http://www.burtonpower.com/parts-by-bran...-kendf8b-s.html available from many sources. I have tested the fan in skip fire mode, I allowed the engine to warm up until it started to skip fire switched on the fan and within 30 to 40 seconds the engine cooled and ran in normal mode.
Posts: 342 |
Hi Rog, very nice job, clean work  ...like it...could you post the exact specs and where to order the fan please. Could you already test the fan in skipfire mode, how does it perform? Smaug This the fan I used http://www.burtonpower.com/parts-by-bran...-kendf8b-s.html available from many sources. I have tested the fan in skip fire mode, I allowed the engine to warm up until it started to skip fire switched on the fan and within 30 to 40 seconds the engine cooled and ran in normal mode. Thanks Rog, sounds like a nice performing...finally have to do the cooling mod
Cheers, Georges
